Question about Marantz Audio Players & Recorders
Hello I have Marantz PM673 and it turns and function fine but suddenly it volumes down and finally no sound, if stays turned on soun come back. If any one may guess what is the problem it will be of great help.
  • leksandor
    leksandor Jun 04, 2011
    I opened it and there is no unusual dust, but I saw 4-5 parts resistors or diodes, 4 in a row and one big resistor with black burn stains. Is there a way of posting photos here?
    Brigadier General:
  • 8,546 Answers
I'd guess something heat-related.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 28, 2011
  • 1 more comment
  • leksandor
    leksandor May 28, 2011
    Thanks, for quick answer, I will open it and dust it then see what is happening.
    Also I read on this forum that "poor solder at the molex type connectors" may be the problem.
  • leksandor
    I opened it up and there is no unusual dust, but I saw 4-5 parts, resistors or diodes, 4 in row and one bigger resistor for sure, with black burn stains. Is there a way of posting photos here?
  • David Dunn
    David Dunn Jun 04, 2011
    I'm sure there are ways to post photos somewhere on the web and postng a link to them but the bottom line is that you can't SEE the root cause of WHY they're burnt. Many posters take a swing at replacing the low-hanging fruit components they can see, then they're back here asking us why it still doesn't work. Online technology hasn't yet advanced to the point where we can see, smell, hear and manipulate the patient device.
    A hands-on tech would have a better chance of resolving the problem with some confidence.
I have a Marantz Digital Integrated Amplifier PM75 and experiencing with LP's and CD's that I get a loud popping sound , thereafter no sound until after several minutes when it comes back on.
If the sound is common to both channels plus on different functions, it is either a part that is common to both channels or is in the power supply. It will be either in the main pre-amp or power amp, or power supply. If you can turn the bad sound down, it's before the volume control and it's unlikely to be in the power amp section. If you can't turn the bad sound down, it will be in the power amp section.
Remember stereo amps are two mono amps joined together. So the two channels have separate parts for each channel. However some use IC's that have both channels running in them, they can be suspects in this case.
Jan 11, 2016 | Marantz Audio Players & Recorders
Marantz Problems
It almost sound like your player is on a standby mode or something if you turn it on and it turns off. You turn it back on and it stays on is because when you think you turning it on, it was actually turning it off. Sound kooky but that's what it looks like to me.
Nov 23, 2013 | Televison & Video
I have a marantz sr4320 receiver. The volume control knob is not working---I can't get any sound no matter the volume number. "d8" is now showing, too, following the number. I have followed...
Do you mean "db"?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Turn the volume down.
While you're squinting at the front panel, find the manual and evaluate every indicator on the face to make sure you understand what they mean and how they might affect operations. Look for Speakers NOT enabled, Muting ON, a Tape or other input inadvertantly selected. If you fail to find the errant setting, treat it like a new install and set it up all over again according to the manual.
Mar 09, 2011 | Marantz SR-4320 Receiver
The volume will only turn up to "0" and barely hear a sound from the speakers. How can i trouble shoot this
I had a similar problem with an SR4320 that I bought used at Goodwill. First of all, turn the volume knob down; 0 db is actually the highest volume. Not sure why Marantz did that; it's counterintuitive. Set it to a more normal volume like -30 db. If it suddenly starts working, you'll blow out your speakers (and possibly your eardrums).
Second, check the back of the unit. There are two RCA connections that say "Pre Out" and "Main In". This is where you could connect another amplifier or a graphic equalizer. But if you don't have either of those hooked up, you need to have them connected to each other. Apparently the unit shipped with jumpers connecting these plugs, but a prior owner must have taken them off.
All you need is a short (1 foot or less) red and white RCA stereo cable. Connect the top Pre Out to the top Main In plug with the white cable and the bottom Pre Out to the bottom Main In plug with the red cable.
Hope this helps! It's a terrific receiver!
May 21, 2010 | Marantz SR-4320 Receiver
Suddenly, I can only hear the sound faintly, even though it's turned up full volume on my Yamaha HTR 5560. What happened? I've played around everywhere with the converter now. Restore defaults anywhere?...
Have you checked the MUTE function?
NEVER turn the volume up more than half-way for any sound problem. Otherwise, if you suddenly find the switch that's out of position you could blow your speakers.
What converter?
What channels, what source(s)?
Feb 27, 2010 | Yamaha HTR-5560 Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
Sony DHC-MDX10 Whitout sound
hello it sound like the output transistor could be the problem also check any capacitors for swelling and any dry joints round the transistor
good luck
shaun
Aug 23, 2009 | Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
My Marantz PM-32 Amplifier has suddenly lost all sound... except for some very quiet higher frequency sound, at very low amplitude (Maybe pre-amplified only)which is just audible with the volume set at...
Hi
First thing to check is to see if someone has turned on the Tape Monitor has been turned on by someone. The symptoms you describe certainly sound like it. Check that out and get back to me if it does not solve the problem
regards
robotek
Nov 07, 2008 | Audio Players & Recorders
Volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Jun 21, 2008 | Marantz SR-5200 Receiver
298 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
