Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
GE Profile trash compactor
The ram is all the way at the top, but when switch is pressed, the compactor just 'buzzes'. GE tech did not even look at the machine and told me it would cost $400.00 to replace the motor. Since the motor buzzes when the power is on, isn't it possible that the problem is something other than needing a whole new motor?
  • 5 more comments
  • jeepdady Dec 22, 2008
    My machine has the same exact problem...If you take out the drawer and pull out the plastic shield on the left or right hand side you'll see the screw that drives the ram. If you adjust this approximately 1/2 a turn, the compactor will work, until there's a load placed on it. Then you'll have to adjust the ram again.
    I still haven't fixed the switch that was reccomended, I saw on another site it was $65 just for a switch.
  • Anonymous Feb 16, 2009
    how do you reposition or adjust the screw?
    how do you adjust those screws on the side panels
    marya.adler@gmail.com
  • brassdog84 Mar 16, 2009
    I have the same ge profile compactor. It too buzzes when you push the button. How exactly did you adjust the screw drive mechanism? And it also sounds like if you adjust this and it works all it tells you is if it's a motor thing or a TPS (top postition sensor) thing. Is that correct? Thanks for the help...
  • csullivan7 Mar 19, 2009
    I had the same problem and had a tech come out and diagnose that it needed a new motor...for $561. Instead, I had a friend who could put a new motor in for us but cannot find a parts store that sells the motor. The only one that had it was not in stock but was only $115. Any ideas on where I could get a motor?
  • maumellemom Apr 24, 2009
    I have the same exact problem, but I am going to try all of those things.
  • randy762 May 09, 2009
    I have a monogram compactor (ZCGS150PSS) with the same issue (motor buzzes). I took the drawer out and pushed the "drawer closed switches" (very dangerous) and hit the compact button. motor still buzzed. so it's not the drawer closed switches. I then turned off the power, removed the bottom pan, twisted the gears by hand, buttoned it back up, turned on the power and everything was fine again. I've done this twice now. the problem will come back. I suspect this sensor. Now I just have to figure out how to get to it and adjust it. Someone had posted a parts blowup of a similar compactor and it appeared the sensor was behind the on/off switch just inside the unit. I will take a look.
Same thing - buzzing noise when pedal is lifted. not sure i understand how to adjust the ram screws though. i have it completely apart and can see them. if i turn them manually with a wrench won't it damage the threads? the ram looks to me like it is a little "off kilter". looking at it from the front one side is a little lower than the other. i have had this thing apart 3 different times i am going to throw it out the window....
Posted on Apr 23, 2009
  • paulcynergy Dec 04, 2010
    I was having the same problem. When it was at the top and I hit the foot switch to start it, it would just buzz. I took off the top and found a pair of shut off switches that get hit by an l-shaped bar on the ram. I took off the back cover over the motor and saw a switch handle on this white round plastic, spring-loaded ring. That seems to be what switches the direction of the motor when the pressure builds. I found on mine, when it reached the top, the white ring was stopped in a place where the switch pushed on a place where it didn't have support. I could adjust this by bending the L shaped bar on the top of the ram to get it to stop a little earlier. The reason why turning the worm screw made it go again was because it moved the white plastic ring to a better position under the switch on the motor. If this isn't clear, you can email me at paul@cynergynetworks.com and I'll try to explain.
  • 706 Answers
Sure is... The motor drives a ram up and down to compact your trash... Like most drive systems.. it needs to find a refrence position near the top of the stroke.. that position is normally sensed by a switch.. so it is possible your motor is bad or.. it is also possible your top sense switch is bad too.. For $400.. the GE tech should come out and stomp on your trash until it is compressed.... In either case.. if you are handy.. you may be able to open the compactor up ( with power unplugged) and check the position of the ram.. if it is near the top.. you may be ableto reposition it down a little then try cycling it.. It may buzz if the motor is bad ( windings shot) or it may work OK.. if it does and the problem comes back after you cycle it.. there is a good chance the top sense switch is bad or the windings in th emotor bad too.. Hope that helps...
Posted on Aug 17, 2008
Why won't the ram come back up on my GE compactall ?
yes you may but there is a limit switch that stops the ram when it is at the top sometimes the piece that goes with the switch will get bent and cause a problem like you are having,
Apr 25, 2014 | Kitchen Appliances - Others
I have a ge monogram trash compactor the ram is stuck in down position, how can we raise the ram?
Start your investigation by removing the bottom plate. There should be a belt or chain going around 3 gears. Mine has 2 metal and one plastic. The 2 metal ones are on the ends of the rods that the ram runs up and down on. The plastic one is on top of a big speed reduction gear that is turned by the motor gear. Don't pinch your fingers but see if you can turn the big gear by hand. All gears should turn. If not check each gear for broken teeth, or bad bearing & races under the 2 rod gears.
Be sure to check t
he threaded hard plastic nut that drives the screw that powers the scissors up and down. This is the part that usually fails.
Nov 24, 2012 | GE Profile GCG1580LSS 15" Built-In Trash...
GE profile trash compactor makes loud noise and pulsates
sounds like you have a bad ram bushing on unit... you will have to pull out and watch operation ...there is also a differential switch that tells unit when to stop that sometimes gets worn and needs replaced... it generally is at the top or on the side of bin ....most likely it is one of the two items that has failed...
Jan 05, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
GE trash compactor ZCG3100BVV-02 won't start. I out a new on/off switch and it still will not start
Most likely a ram position switch but could also be a bad motor. process of elimination will lead to the faulty component...Eric
Sep 12, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE trash compactor foot pedal loose
Take a chance and type: "SearsPartsDirect" into the search engine of your computer and when you get that web site, type in your model number off the machine.
If this works, you should get a schematic showing you the parts and part numbers, and maybe even the opportuninty to order the apart you need.
God bless your efforts.
Nov 20, 2017 | GE Profile GCG1700LII 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile compactor
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Aug 19, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash compactor problem
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Jan 11, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
1,345 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
