I lost my audio input cables for Sennheiser T30 wireless headphones. There is a rectangular 3 pronged receptacle on the transmitter/base/charger to receive the cable. Can I buy a new one or make an end to convert to the red/white RCA jacks out of the TV? Tim
  • 119 Answers
SOURCE: audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Posted on Nov 03, 2006
DirtyDozenUK
  • 57 Answers
SOURCE: I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Posted on Feb 07, 2009
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
SOURCE: RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Posted on May 30, 2009
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
No sound from my sennheiser 840s
Hi Suzanne, I want to help you with your question, but I need more information from you.
If you step back and look at this problem, there are two to three things that immediately come to mind: 1) have you hooked your headphone input to an output of another device like an amplifier or tv or ...? 2) Are you certain that the headphones are charged and the power to the base station is good 3) pairing the headphones to the base may be an issue.
Please clarify some things and anything else you can think of. Chad
Dec 27, 2014 | Sennheiser Set 840s Rf Tv Amplifying...
Sennheiser HDR120 - missing transmitter / alternative OR replacement?
The system is working in the 860 Mhz range, so not that common. Most of the time it is cheaper to by a complete new system then to tray to buy components. Just keep looking in the thrift stores you find a transmitter for this headphone for a good price.
Jun 15, 2014 | Sennheiser HDR 130 Consumer Headphones
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Dec 16, 2008 | Sennheiser RS 120 Consumer Headphones
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
Connecting wireless headphones
You should be able to get a cable with your headphone jack on one end and the standard left and right RCA jacks on the other end from just about any electronic store. Carl.
Sep 09, 2007 | Denon AVR-2807 Receiver
158 people viewed this question
 Grubhead
Grubhead
