Question about Opti -UPS PowerES 1000 UPS System
Will not recycle to line power with any load - Opti -UPS PowerES 1000 UPS System
  • 543 Answers
Problem of your UPS is from battery, change battery / there is two , 12V 7or 7.5 AH/, and that ups will work.
Posted on May 28, 2011
Why does brine tank fill with water and overflows?
It sounds like there is a problem with either the valve in the head not sending water to the venturi jet when it is supposed to recycle or, the venturi or jet have an obstruction that is preventing it from creating the vacuum necessary to draw the brine back from the tank into the resin bed.
If there is water flowing out of the drain line during the recycle it is probably the venturi or jet need cleaning. If no water is flowing it is probably the valve assembly.
Nov 28, 2014 | Plumbing
I have changed all 4 inks and cleaned numerous times but still get loads of white lines running through where it should print solid black.
White lines occur when the print-head is partially clogged. So, if "cleaning" has not helped, it's time to either take the printer to a qualified technician, or to responsibly recycle the printer, and buy a replacement.
Jun 11, 2010 | Brother DCP-110C All-In-One InkJet Printer
After a short power outage (resetting breaker) the protected outlets no longer provide power. Is there a way to fix or do I need a new UPS?
The unit may need to recycle itself. Remove the loads and turn the unit off. Plug it back in, wait a bit, then turn it on. Then try your loads on it again.
Feb 18, 2010 | Tripp Lite Tripp-Lite HT1500UPS Home...
When my Gateway 300S is powering up, it recycles.
If you repeatedly hit F8 key when the computer starts to boot it will open the boot menu screen. There should be an option to "halt computer on all errors". This should bring up the blue screen of death. It should give you something like
STOP: 0X0000007E, the a whole bunch of other numbers. after that it may display a file name. You can search the internet for STOP: 0X0000007E and the file named mentioned. You may be able to find a solution by doing this. It is usually caused by a bad driver or executing a bad command on Windows start up. You can boot the computer in safe mode from the boot menu and maybe repair the problem but it's a tough one to find. I'm trying to repair a similar Gateway computer. It doesn't list a file name and I'm pretty sure that it's a video driver or the onboard video card. The problem is Gateway is no longer in business and it's hard to find updated drivers I"m going to try to backup all the files on the drive and re-install windows and try to repair the drivers with more updated ones. The gateways are hard because they don't have slots in the motherboard to install anything but an old PCI video card. It may be time to think about a new computer soon.
Nov 14, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Manual steering exchange with powersteering
Try a auto recycling yard and ask for the rack, power steering lines, pump, and accessory bracket. Some yards also install which can save you from looking for extra parts. The recycler should have a parts interchange manual to know what years and models interchange.
Feb 06, 2009 | 1995 Toyota Pickup
Computer reboots
Hi cool,
Is your Computer keeps on recycling from booting and never finish to load your OS?
As far as i know you got a problem with you CPU, your computer processor is overheating inside that's why it keeps your PC recycling it's power.
Try to go to the BIOS setup menu, and go to the cpu temperature and you will that your PC is heating up.
Hope it helps & give you an exact reason.
Enjoy.
tnx
-micro
Feb 10, 2008 | Computers & Internet
Power failure problem
Run an extension cord to another outlet and try it again.  Usually it's the plug that has the problem.
Sep 27, 2007 | LG WM2688H Front Load Washer
Opti -UPS PowerES 1000 UPS System Logo
110 people viewed this question
Top Opti Computers & Internet Experts
David Payne
David Payne
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
