Question about Onkyo TX-SR605 Home Theater Receiver 7.1 Channels
My TX-SR605 has two HDMI In slots. I want to add a third HDMI device - a ROKU box. Please advise how best to do this. Thanks.
    President:
  • 2,992 Answers
Use an HDMI switcher like this. Then you can select any of the three inputs and run it to the receiver. Simply leave the receiver on that input and use the switcher for source selection.
Posted on May 28, 2011
My SR 606 has two issues. First, it takes a long time to switch tv over from normal channels to HD channels. Second, the DVD and Game selections are no longer working. I get a "no signal" message. The...
I'll second what dennisae said. I've got a TX-NR708 that had all sorts of video issues after about 6 months of use until I got the HDMI board replaced. This seems to be an issue with this brand over a wide number of models.
Oct 11, 2013 | Onkyo TX-SR605 Receiver
Can I plug a PC into one of the Onkyo HDMI ports? (TX-SR605)
Mike, I would agree. ANY device that either IS or emulates any hi-fi A/V device should work just fine assuming it doesn't deviate from the hardware standards of the 'real' hardware. Your Media PC is just another digital source as far as the receiver knows. Manuals don't mention everything because it is assumed that we know we can substitute compatible devices among the various in/outputs.
However, my own practice is to run every signal directly to the best device that enhances or uses it. NO VIDEO to my AVR (it goes directly to my monitor); NO HIGH-END AUDIO to the TV (it goes directly to my receiver). NO EXCESSIVE CABLES. NO PROBLEMS WITH UNNECESSARY CONNECTIONS. NO CORRUPTION OF ANY THE SIGNAL.
My PC's soundcard feeds both digital and analog audio inputs on my receiver so I have the flexibility of manipulating it in the analog domain for re-recording or just listening.
Nov 10, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Hi We have the Onkyo TX-SR605 and have been trying to preview 3-d on our Direct TV and new Samsung 55" 3D capable TV. However, the TV problem solver says that the receiver may not support 3D...
I have a '608, and it supports 3D because it has HDMI 1.4. It looks like the 605 only has HDMI 1.3.
The original HDMI 1.3 protocol is not 3D capable, but revisions a/b/c support it. You should check to see what HDMI revision the 605 has.
Apr 20, 2011 | Onkyo TX-SR605 Receiver
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
I have an Onkyo TX-SR605 AV receiver that just stopped outputing video to my Panasonic projector. I have connected other devices directly to the projector and video is fine, so the problem is not the...
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Nov 27, 2009 | Onkyo TX-SR605 Receiver
No video signal on my tv fron the TX-SR605
IFF YOU ARE USEING HDMI FROM AMP TO TV SET HDMI OUT PUT ON IN AMP MENU, FIRST BY GOING TO SET UP MENU IN/OUT ASSIGN PRESS ENTER ,MONITOR OUT NOW ON AMP, PRESS ENTER TO SEE HDMI MNTR AND PRESS RIGHT ON ENTER BUTTON TO SWITCH ON.IFF YOU ARE NOT USEING HDMI TO TV LEAVE HDMI OFF AND PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP TO SELECT THE TYPE OF CABLE YOU ARE USEING FOR AUDIO,EG OPT1 OR2 COAX 1 OR 2,IFF YOU ARE USEING PHONO CABLES SELECT _ _ _ .MAKE SURE OUT PUT ON SKY IS SET TO RGB.
HOPE THIS HELPS.
CABLE GUY.
Mar 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Feb 08, 2008 | Onkyo TX-SR605 Receiver
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Nov 26, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Home Theater Receiver 7.1 Channels Logo
217 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
