Question about Dayton Audio Dayton 1FYX2 Bench Grinder
I lost a lot of power on my Dayton bench grinder. It's older and I'll admint, I've never done any maintainace on it. Any ideas?
Is the 4A912B Dayton 10" 1 HP bench grinder 3 phase or 1 phase?
If the plug on the cord has 2 flat prongs and one round one then its 110 VAC single phase. If the motor has 4 wires then I'd suspect 3 phase. The data plate on the motor will tell you for sure.
Nov 19, 2014 | Bench Grinders
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
I have a Baldor 1022W grinder but i'm not sure how it is wired. I've tried looking for wiring schematics but have been unsuccessful. All I need to know is how to tell if the grinder is wired 115V...
first off what does the plug look like? that would be one clue and also usually under the bottom plate there is a wiring breakdown. Let me know if you need more help
May 12, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I have a single speed Delta 8" bench grinder. How
as for slowing it down, no problem. Hook it to a cord with a dimmer switch connected to it. Make sure your running with the same power rating though. As for a dripper, no ideas just yet.
Mar 10, 2011 | Delta ShopMaster 8in Grinder with Light...
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
I am looking for a Dayton Bench Grinder Manual...more specifically a parts breakout. Dayton Bench Grinder Model 1Z707W. Thanks, Mike
I would try and call Grainger parts to see if they have one. I know they deal with and sell Dayton equiptment. If no luck let me know and I will try and find another source.
Feb 16, 2010 | Grinders
Need part numbers to replace eyeshields on Dayton bench grinder
Your grinder is listed on page 3085 of the Grainger catalogue. The part number for the eyeshield is 00281.00 and the number for the lower eyeshield bracket is 00280.00. The right hand upper eyeshield bracket is number 25188.00 and the upper left hand bracket number is 25177.00. All of this can be ordered through Grainger at 1-800-323-0620. Marvin T.
Jan 13, 2010 | Grinders
Bench grinder, 110/220?? wired up properly according to diagram on grinder, just turns on as soon as it's plugged in but it just humms, it does not spin the grinding wheel.it is a monster w/ a 3/4 hp...
LIKELY the capacitor which is usually in the base is bad.
The capacitor shifts the phase angle in one of the two windings which creates a pseudo rotating field to start rotation.
Nov 07, 2009 | Saws
Dayton Audio Dayton 1FYX2 Bench Grinder Logo
63 people viewed this question
Top Dayton Audio Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Dayton Audio Grinder Expert? Answer questions, earn points and help others
