Question about Garden
My prime bubble sticks in when I try to prime my leaf blower.Blower will not run.
  • 2,239 Answers
There must be a blockage in the fuel system, start by replacing the fuel filter in the fuel tank, if this does not work remoce the carb and clean the internal filter under the pump cover.
Posted on May 28, 2011
Testimonial: "The internal filter is the problem. For what ever the reason when I prime the bubble the filter is getting saturated with gas and causing a vaccum.?"
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
How can i fix a primer bubble that hisses
Here's a link to your poulan part site,you probably need a primer bulb,lowes,homedepo,or sears may have them. http://www.repairclinic.com/Shop-For-Parts/a27b345/Poulan-Leaf-Blower-Parts
Jul 21, 2015 | Poulan Garden
Why is the dip stick blowing out
You must have blown a gasket. Most likely the head gasket. Won't take long till the motor stops complete.
Mar 31, 2015 | Garden
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
Sthil bg 86 blower prime bulb work but blower dies try prime again nothing it put pressure in tak
It could be starving for gas at high rpm.
Check the plastic gas lines between the gas tank and the carburetor.
Replace if even the tiniest crack.
Aug 06, 2014 | Stihl Genuine Sthl Bg 86 Leaf Blower...
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Leafblower won't start
I assume this is a Gas blower? So first off is the gas bad? Did this blower sit for a prolong time? These do require premix fuel and you must add 2 stroke oil to the gas ... if you don't you will ruin the motor. Check the spark plug for corrosion. Also it should have a gas bubble to prime the Carburetor with ... make sure gas is flowing through this bubble you can tell buy pressing the bubble you should feel and hear the gas squish thou it. Also check inside the gas tank look at the feed tubes make sure they are not deteriorated if they are you may just need to get a new one. Good Luck
Sep 29, 2009 | Craftsman Garden
Blower stall after few seconds
sounds like you not getting enough gas,or you are getting air in gas line,, check for air bubbles in gas line,, if you dont have any then clean the carb. good,, hope this help you
Aug 29, 2009 | Homelite 'Yard Broom' Leaf Blower
My tro bilt model tb320bv gas leaf blower will not run at full th
The carburetor may need to be taken apart and cleaned or rebuilt. If you haven't taken one apart before your best bet is to see if you can get an after market carb for it, that would probably be the cheapest way out.
Jan 12, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
