Question about GE 35GT740 35" TV
No coaxial connector on tv
How can i plug my coaxial cable from wall to tv without coaxial connector on tv (without usin a vcr)
    Sergeant:
    Champion:
  • 298 Answers
If it has an antana input the two screws on the back, you get an adapter from almost any department store for around 3 bucks.
Posted on Aug 16, 2008
SOURCE:
I have a cable paid for but My male coaxial cable from the wall doesn't fit into the antenna-in on the UN40c7000. It seems I need a coaxial cable adapter. I can't find the right size. How can you help?
Is the connector coming out of the wall too big or too small for the connector on the TV? If too big you should be able to still plug it in it will just be loose, and you can check that your signal is working etc.
This is very strange as coaxial cables have a very standard size, and do not vary. Unless it is a mini coax cable which is very tiny and right off the bat you can tell it wont fit. If that is the case then you need to get a converter.
Otherwise you may be able to use something like this http://www.amazon.com/10pcs-Frequency-Barrel-Connectors-Couplers/dp/B0037JB75S/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1381528325&sr=1-1-catcorr&keywords=coaxial+barrel
and tape the one end and use a regular cable to your TV. I would first purchase another cable and ensure that it will fit on the TV to ensure the connector on the TV is indeed the right size.
Oct 11, 2013 | Samsung UN40C7000 TV
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
Second.. the VCR usually has a VCR/TV setting..
Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
Repeat this on Channel 4
Check your cable to make sure the connections are tight.
Finally check your television menus for Input settings..make sure it is set to COAX/ANT
Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
Best of luck!
Apr 22, 2011 | Televison & Video
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
Coaxial cord won't fit on VCR/DVD
Are you sure that the port that is unthreaded is actually coaxial. I've never seen an unthreaded coaxial port, just unthreaded push on connectors.
What color do you see on the center ring on the connection of the vcr?
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd without coaxial, old tv without RCA, passthrough VCR died
http://www.ellies.co.za/v2/index.php?id=492
@ tihis link above you can see it. It takes the av SIgnal Your Sound and picture and convert it RF making it possible for your tv to tune it, its just like tunning into a station. I do sell these for R199 South African Rand excluding postage
Thank you for using FIX YA
Jan 04, 2009 | Televison & Video
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Coaxial input jack on the TV broken off so I cannot connect my coaxial cable from wall
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Sep 18, 2006 | RCA D52W19 52" Rear Projection Television
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
GE 35GT740 35" TV Logo
667 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
