Question about Vacuums
Kenmore Model 116 28014700 intuition vacuum cleaner. Latch for hose connection to cannister broke. I have the new part. How do I remove the hose from the broken part and replace it on the new part? I have already purchaed the new part p/n KC92PDDUZV06 for this, bt can't figure out how to get the old part off. It looks like you must destroy old part in order to get it off.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Kenmore Model 116 28014700 intuition
Hi
To remove the broken part from the latch use a small screwdriver to release the tabs on the latch on the connector. When latches are released the latch assembly and the plate will slide out of the connector. When the plate is removed the adapter and hose will slide off the connector. Release the tabs that hold the hose to the adapter and put the hose on the new adapter.
You need to position the terminal plate inside the adapter before sliding the adapter and hose on the new connector. The latch and terminal plate have to slide under the small guides on the connector. Its reverse of removal. Please check the pictures in the below link, it may help---
Link 1
Link 2
Link 3
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 06, 2011
When I replaced the bag, the bag replace light comes on unless I don't use any attachments. what is the problem?
Could be a blockage, push a broom handle through the pipe that will clear it.
Oct 18, 2014 | Kenmore Vacuums
My Dirt Devil Envision #086710 is not picking up. Hoses clear, new belt, brush cleaned of hair etc. Air leaking from the place where the cord comes out of the vacuum at the bottom is this normal?
Sounds like you may have a hole in a hose somewhere. Check the internal hoses and make sure they are connected correctly. Check that your cannister is locked in. This may be preventiing suction also.
Sep 27, 2014 | Dirt Devil Envision Vacuum Cleaners
Dyson hose is broken how do I replace it
The colored pieces on the vacuum are latches. You can remove most parts. For the hose, you may have to remove the cannister to get to the latch through a hole in the main upright part of the vacuum. You can find parts with a search of the Internet. You will have to get the hose with both ends attached, but one source has it for $21.95.
Oct 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Is there an operating manual on the web for a Kenmore Intuition vacuum cleaner
Hi, here is a link to a site that holds the manuals, but you will need the model number of your cleaner. Hope it helps! Please rate me. :) http://www.managemylife.com/mmh/owner_manuals/search/product_type.Vacuum,%20Upright?query=Kenmore
Jul 17, 2010 | Kenmore Vacuums
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
Kenmore cannister style. Cannot remove the
It depends on the model you have. Do you know the model number? If you need a replacement belt you can get one here:
http://www.vacbelts.com/kenmore.htm
Oct 25, 2009 | Kenmore Vacuums
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Kenmore Bagless Issue
after cleaning the filter,replace the bag.But this time before you close the lid,make sure you remove the hose.after the lid is closed then put the hose back on.
leaving the hose connected to the lid after closing will create a gap between the bag holder and the bag.so just remove the hose first before changing the bag
Jun 16, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
145 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
