Question about Seagate Barracuda 7200.11 - hard drive - 160 GB - SATA-300 SATA II
Require replacement power/data pcb for a seagate barracuda 7200.11 1000Gbytes part number on PCB is 2HBAHNRQ
  • 1,179 Answers
Contact your local computer store, a computer technician/data recovery technician may have just that circuit for you to use and transfer your data onto a new hard drive.
You may also try to contact Seagate in this regard, they offer 3 year warranty on all Barracuda hard drives.
Take care!
damnor01
Posted on May 28, 2011
What is the Internal Interface of Barracuda 7200.7 ST380011A
READ THE MANUAL AT SEAGATE.
or look at the chips there, see those I/O chips
see the p/n on them. look them up and read the data sheets.
see the pata pins, see them , enter the PCB with copper traces
they land on the I/O chip, and is clearly labeled on all mine.
great question, I worked as and ATE test system programmer and we do this all the time. There are many tests. not just i/o.
Oct 10, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Data recovery from a seagate barracuda 7200.10 500 GB with a PCB chip problem
You can recover hard drive data with hard drive data recoverysoftware. Thenformat the drive to get it fixed.
For data recovery software,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Sep 02, 2011 | Seagate BARRACUDA 720010 ST3500630AS PCB...
My Seagate 1TB SATA hard disk's PCB main I.C. is Broken & noise of Clicking and Not Detecting in BIOS.. I'm in big trouble please help me.!!!!!PLEASE PLEASE....
I am afraid the device is dead. You may be able to recover the data from a professional recovery firm but there is no other way.
Dec 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate ST3160215A Hard Disk PCB Card Short-160 GB ATA
Hi sunny_2003,
There are many hard drive pcb supplier such as http://www.hddzone.com/seagate-pcb-c-1.html
Be sure to backup your data.
Mar 11, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Need to find PCB for Seagate ST380021A 80GB Hard Drive
Hi - Your best bet is eBay or other online auction. I found 7 for sale including a seller in Canada with just the PCB for sale.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Computers & Internet
Replacement PCB
http://cgi.ebay.es/Barracuda-7200-7-ST380011A-FW-3-06-P-N-9W2003-314_W0QQitemZ200251188516QQihZ010QQcategoryZ64462QQtcZphotoQQcmdZViewItem
or
http://cgi.ebay.es/Barracuda-7200-7-ST380011A-FW-3-06-P-N-9W2003-354_W0QQitemZ200228867743QQihZ010QQcategoryZ64462QQtcZphotoQQcmdZViewItem
Jun 12, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Hi, your query, "is there a way to fix it?" if you intend to use if again normally, afraid no way; if you want to recover/retrieve important data/files, probably: 1. seal the drive in a sandwhich ziplock plastic bag, leave it in your freezer overnight, install as a secondary master in another PC, autodetect in CMOS, if detected, boot to your OS, copy whatever you can real quick, soon as it reaches ambient temp chances are it will no longer be readable again; or 2. assuming it is an electronic problem, using a torx driver remove the pcb, get hold of another hd of same brand & model, borrow the good PCB and tempo use it, again install as secondary master in another PC. if no available 2nd HD at hand, install and while in CMOS autodetect HD, feel around the PCB components and determine which heats up faster than the others, spray it with a contact cleaner, if detected continue to your OS to back it up, continue spraying to maintain lower temp; 3. assuming mechanical problem (though highly unlikely) lightly tap with a small rubber mallet (rubber coated handle of a side cutter will do) bottom of drive and install; 4. assuming an electrical connection problem, reheat the 4 power terminals at the bottom (+, gnd, gnd & +) and/or remove the pcb and check/clean contacts at the back of the PCB and its mate, 2 sets; 5. assuming you can do component level soldering and can use a VOM, check surface mounted fuses on PCB near power connector. All of the above are last resort and are not guaranteed to revive your HD. Most require that you run your unit open with possible risk to electrical shock. If you are not comfortable, it would probably be to your advantage to seek the services of a qualified service professional. Sometimes it work, sometimes not, hope it be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Seagate Barracuda 7200.11 - hard drive - 160 GB - SATA-300 SATA II Logo
143 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
