Question about KitchenAid Dryers
My dryer is running but it's not drying my clothes, no heat is coming out.
  • Robert Froman May 28, 2011
    Is it an electric or gas dryer? Does it get warm inside the drum where the clothes are?
  • 127 Answers
It is most likely from using too much dishwasher detergent. If it is try rubbing with white distilled vinegar If the white scum has been on for a long period you will need to rub a lot. After you rub the dish, glass or pot, rinse and let dry. If you have not rub enough you will see some of the white scum come back. Keep rubbing and rinsing until all the white scum is gone.
Posted on May 28, 2011
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Clothes dryer doesn't heat
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 26, 2011 | KitchenAid Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
60 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
