Question about Pentair Easy Touch Indoor Control Panel for 8 Function Systems
Our Pentair control panel is not aligned to the actual pool temp. The control panel reads that our pool is 102 degrees and the actual water is ice cold. It been this way for days. I turned the panel's heat to 104 and the heater kicked on. The control panel needs to be re-booted. Can you help?
Temp sensor is bad.
Posted on Jun 22, 2011
My Pentair Mastertemp 400 temperature is reading 20 degrees too low. I've replaced the thermistor already. Any ideas?
bummer hi limit wont do that but tep sensor will or control board also make sure water is flowing freely,
you will want to check the manifold bypass and thermal regulator
May 29, 2014 | Pentair Mastertemp Heater
LED panel on heater does not light up and water temp reads higher then actual 107/64 degrees on control panel
This is an indication of a bad water sensor. It also tells me that the pressure switch may be bad because if it is working then the light on the panel will light up telling you that the spa water is heating.
Rod
US Parts Center
Oct 20, 2013 | Pentair Pool & Spa
Heater will not come on.
controller temp sensor bad
Jan 06, 2013 | Pentair Mastertemp Heater
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
Pentair Mastetemp Pool and Spa Heater will heat to about 91 or 92 degrees and thats it. We have it set at 102 but it stops at 92 at the most.. It fires up then quits, fires up then quits. What could be...
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 19, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
I have a minimax ch 150 heater and the heater is running but the water coming out is not as hot as it used to be. Though the heater is extremely hot on the outside. Any tips?
Check your SENSOR. With the Minimax ch heater, you might be using an 'IntelliTouch' panel that controls your equipment. If you are, check the reading that the panel says the water temperature is and then check the temperature of the water 'coming out' (spa??) manually with a floating thermometer. When the heater cycles off, check the difference between the 2 numbers. Say the panel says 102 & the thermometer says 95?? - that is a faulty sensor, telling the heater that the water has reached 102, so it cycles off before ever getting hot. If you're not using the IntelliTouch, you will be checking the display panel on the actual heater itself & again the floating thermometer. Now... if the temperature is less than a 4 degree difference you can always calibrate/or have calibrated the heater.
Aug 03, 2010 | Pentair MINIMAX NT TSI IGNITER
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair Easy Touch Indoor Control Panel for 8 Function Systems Logo
352 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
