JVC TH-R1 home cinema DVD player. A disc was put in and message flashed open/ close constantly. Turned off at mains, now flashing Please Wait constantly and cannot get machind to do anything. Have tired switching off for some time, holding down on/off switch.
techman
  • 3130 Answers
SOURCE: amp keeps switching off
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
Posted on Apr 29, 2007
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
Posted on Nov 26, 2007
SOURCE: Panasonic SA-HT692
Thanks for your help, but I couldn't wait any longer and took care of the problem. This is what I did to fix it: With the dvd player unplugged, I removed all the screws and opened up the dvd player to make sure that there was no dvd stuck inside. Once I confirmed that there were no obstructions, I then proceeded to plug in the dvd player so I can see how the player reacted to the error messages. I noticed that every time I pressed the eject button, the section where the sensor reads the disc was slightly moving but not fully reacting. So right above the laser sensor apparatus, there's a white plastic circular piece and I moved that around a few times and it did the trick. Problem solve, the dvd player is working like a champ. Hope this helps if someone out there that has the same problem.
Posted on Feb 13, 2008
SOURCE: JVC KD-G431 IN CAR CD PLAYER "000ZAAA" Error
I had the same problem. It started when I tried to play an MP3 track from a "Creative Zen Vision M" Media Player. The result was the same as you describe = Maddening. It was extremely annoying that the CD player did not work. I thought I had broken the equipment.
Then my wife read the product hand book , and noticed on page 2 http://jvcmobile.co.uk/documents/products/KD-G431%20Instructions.pdf it showed, where using a pen you can reset the equipment back to the original settings. I thought I might as well give a try. It worked = Fixed. Amazing. I was so relieved. Such an easy solution.
Give it a go. I reckon there is a good chance it will fix your problem, and you will also be very relieved. Just use a basic MP3 player in future. GOOD LUCK !!!
Posted on Mar 22, 2008
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
Jvc th-s3 won't turn on...blue light flashes briefly and then goes out
from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
Take care.
May 13, 2010 | JVC TH-S3 System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Tray locked
Dear friends,
I have solve the problem.power off the player and press and hold STOP+OPEN,CLOSE button.and than power on the player than display shows unlocked.the problem solved.and enjoy
Dec 30, 2008 | JVC THS55 System
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Dvd is locked into machine,how do i unlock it?
Hi Hope this will help on the main machine while in standby press the eject button with the stop button press and held ,try that
Nov 29, 2008 | JVC TH-M45 System
I have a jvc th-p7 cinema system. and when i try to open the tray it say's locked. but i dont know how to take it off?????
You can lock the tray and prohibit the unwanted disc ejection.
On the center unit ONLY:
While the system is turned off
• The system turns on and "LOCKED" appears on the display
window.
• If you try to eject the disc, "LOCKED" appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and "UNLOCKED" appears on the display
window.
Nov 27, 2008 | JVC Televison & Video
Disc error
Assuming you've tried regular nonrecorded DVD discs, there are many things that can cause this:
Dirty or defective laser. (try a cleaning disc).
Disc not spinning.
Laser not moving on slide rail.
I would at least try cleaning the laser lens before giving up.
Hope that helps...
Geno
Mar 24, 2008 | Televison & Video
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
96 people viewed this question
 Grubhead
Grubhead
