Question about Kenmore Dehumidifiers
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
    Brigadier General:
  • 4,736 Answers
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
Posted on May 28, 2011
It is not taking moisture out of the air. The tank is bone dry, yet the controls indicate it is in moisture removal mode, the fan is running and the temp gauge shows 60% rh. Also we suspect it is drawing...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 28, 2011 | DeLonghi DE500 Dehumidifier
Kenmore 34351 dehumidifier compressor does not work. fan works on hi and low, fuse is good. what could be the most likely cause?
heatman101
Jun 01, 2011 | Kenmore 54351 Dehumidifier
Unit runs but doesn't collect water and there is a lot of water in the basement. Have had dehumidifier for two weeks and was working well before.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. Also, it's not uncommon on some dehumidifiers for the fan to almost run constantly. It's designed to keep the air moving, in a effort to detect when the humidity level rises.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter no is the time to check and clean it. And while your at it, clean the cooling coils too. Since it sounds like this unit has been working hard for 2 weeks.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 15 to 25 minutes and check the water collection bucket. If there's water in it, it's working as it should.
For more information on the proper operation of a dehumidifier, go to the Tips section of Fixya and look up "Taking the confusion out operating a dehumidifier".
Hope all this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Dehumidifiers
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
My Danby Dehumidifier has stopped drawing water even though the fan kicks in. Do you have any suggestions? The fan has been cleaned and the humidity setting is 35.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 08, 2010 | Danby DDR2504 Dehumidifier
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
Aug 10, 2009 | Maytag M7DH65B2A Dehumidifier
LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Jun 01, 2009 | LG DH404E Dehumidifier
Kenmore 54501 Dehumidifier Problem
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jul 17, 2008 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
201 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
