Question about Toshiba PA3235U-3BTM Network Adapter
Tobhiba Satellite M35-S320 - Downloaded Windows 7 - can not connect to internet - I use a wireless connection - appears I lost network adapter during download of 7
  • 543 Answers
You lost your PC drivers, You must find driver for network adapter for windows7, after install it apdate you drivers for windows 7 from toshiba.com
Posted on May 28, 2011
How to generate Response Code for challenge code for bios on m35-s320
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen user Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 23, 2012 | Toshiba Satellite M35-S320 Notebook
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
Im trying to find how to rebot my laptop back to factory its a toshiba satellite m35-s320
Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
  • 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
  • 3) When the machine Starts beeping; release the 0 key.
  • 4) When prompted by the warning screen; select Yes to continue with the system recovery.
  • 5) Select Recovery of Factory Default Software; click Next.
  • 6) Select Recover to out-of-box state. Click Next again.
  • 7) Click Next to Start recovery.
May 18, 2010 | Toshiba Satellite M35-S320 Notebook
I have a msi PC60G Wireless card but it doesn't seem to want to connect with my new Windows 7. What can I do?
Windows 7 should download the driver by itself, try to connect the pc to internet trough a wired connection and run windows update, then look in the "optional updates" and select the checkbox of the wireless card item. once downloaded windows shold install it alone. I hope you can make it work!
May 12, 2010 | MSI PC60G (MS-PC60G) Wireless Adapter
Toshiba M35 S320 touch control buttons have stopped working. How do I fix it?
The TouchPad is enabled by default. To change the enable/ disable TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click the Mouse icon. 4 Click the TouchPAD ON/OFF tab. The TouchPAD ON/OFF tab view window appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply. 7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window. 9 Close the Control Panel window.
However, still if it does not work, you need to download drivers for touchpad.Here is link to download the drivers for touchpad. Under the "All categories link choose Touchpad"
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556040&rpn=PSM30U&modelFilter=M35-S320&selCategory=3&selFamily=1073768663
Mar 27, 2010 | Toshiba Satellite M35-S320 Notebook
How to connect wirelessly on Toshiba
try going to your device manager, on the network adapter field, make sure you see the wireless adapter and enable it.
Feb 14, 2010 | Computers & Internet
Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Dec 29, 2009 | Belkin F5D9050 Wireless G Plus MIMO USB...
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Replacing M35-S359 motherboard with one from S320?
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Jan 29, 2009 | Toshiba Satellite M35-S320 Notebook
Toshiba PA3235U-3BTM Network Adapter Logo
343 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
