Question about Turboair Turbo Air Sandwich Salad Table 72" GSP-72T
How do get to evap fans? One of them is causing the unit to pop the GFI.
  • 3 more comments
  • wren_dean May 29, 2011
    All three fans are running but the GFI is tripping? Should I isolate each fan individually and see which one is causing the fault or what should I do?
  • wren_dean May 30, 2011
    The fans are not causing the problem. I am getting resistance to ground, could it be one of the heaters and if so how do I get to them?
    I took the fans out of the circuit and it continued to trip (compressor circuit was off) the only thing left is the cabinet heaters? How do you get to the heaters?
  • wren_dean Jun 01, 2011
    I isolated all the fans and the unit is still tripping, the only thing left is the two heaters. Is there any way to isolate the heaters from the circuit? Or test and repair them?
    I isolated the fans from the circuit and the unit is still tripping. The only thing left is the two cabinet heaters, How do I test them? Can I isolate them from the system? How do I get to them?
    President:
  • 1,902 Answers
Http://www.tmeinc.biz/xturboair.htm
This is the only link that I could find, it looks like you can get the motor only or the motor and the fan complete.
Posted on May 29, 2011
  • Turboair Master
  • 19,396 Answers
Hi.
To reach the fan remove panel located behind the pans:
If instead you need to reach thermostat and evaporator, remove the panel at the back of the refrigeration compartment to reach the evaporator at the back.
Here the full service manual:
SERVICE MANUAL DOWNLOAD
Regards.
Ginko
Posted on May 28, 2011
  • Ginko
    Ginko May 29, 2011
    Hi.
    Exclude one fan at the time, and find out what fan is tripping. The test is very simple.
    Regards.
    Ginko.
  • Ginko
    Ginko Jun 02, 2011
    You do not need to give the experts assisting you bad feedback to get a refund. The feedback given to the experts does not affect your rights.
    Enjoy...you have had our time for free.
What would cause intermitant pop of ground fault. only thing on the line. ground fault has been replaced
Refrigerators are not recommended to be plugged into a GFI outlet. Depending on the age of the fridge there will be spikes in the current the fridge uses at certain times causing the GFI to trip. A GFI outlet is much more sensitive to current than a non GFI outlet that is tied back to the the regular breaker in the electrical panel. Pleazer Appliance...
May 06, 2014 | Whirlpool Refrigerators
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
When my Mark 6 does its job and shocks a cow it pops the GFI that it is plugged in to. How do I fix that?
Replace the GFI with a standard plug. the unit has its own ground return which cause the GFI to trip.
Jul 10, 2011 | Parmak Solar Fence Charger
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Washing Machine Pops GFI Circuit
I agree. could be heater or motor..try disconnecting one wire on heater then trying if still same try unplugging motor plug ...this will say which one..please leave feedback..
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Model: ed5fhexnbo1 ....Noise comes from freezer side; sounds like the motor or fan is rubbing something. This occurs intermittently. Ken
You could have bad bearings in your evaporator fan motor. I would also check your fill tube for your icemaker and make sure that it has not frozen and popped out of place. Sometimes they will pop out of place and when the icemaker is filling it will drip some water down onto the evap fan blade causing it to rub on a block of ice. If theres not ice build-up then replace the evap fan motor it should take care of your problem. Part# 4389144
Hope this helps _MJ_
Feb 10, 2010 | Whirlpool Refrigerators
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
Beverage air dd78 comp.wont start..tripping GFI
Refrigerators often will trip the gfi via the compressor. If you have checked all the wiring. The problem is likely in the compressor windings. I have had this occur in brand new units. Another thing to check the gfi, less expensive gfi outlets do not handle refrigeration equipment well. You should consider getting an industrial rated outlet. Hope this helps.
Oct 22, 2007 | Beverage-Air Beverage Air 2- Tap Unit...
Turboair Turbo Air Sandwich Salad Table 72" GSP-72T Logo
118 people viewed this question
Top Turboair Refrigerators Experts
David Jewell
jasbo
jasbo
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
