Question about SuperMicro SUPER DP8-G2 (P4DP8-G2) Motherboard
I have a 3 SuperMicro P4DP8-G2 motherboards that have no video at start up and do 2 types of beeps after a few min. 1 long beep with short beeps continuously. and the other is 2 long beeps continuously. Note i got these without the cmos battery but i put one in all of them and cleared the cmos before i turned them on to test them.
  • SuperMicro Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on May 28, 2011
X6dh8-g2+ no video continous beep
Hello here is the homepage:
http://www.supermicro.com/products/motherboard/xeon800/E7520/X6DH8-G2.cfm
Try to boot with only one stick of ram at the time, to find the failing ram module.
This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud sound, if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
The mainboard is useing Up to 16GB DDR2 RAM.
Try not to buy cheap ram, they are always failing.
Good luck
Feb 21, 2013 | SuperMicro Computers & Internet
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
What do the red diodes D1 - D4 mean?
I do not see anything in the manual about LEDs for D1-D4
Super Micro Computer Inc Products Motherboards Xeon Boards X5DP8 G2 .
However if the motherboard is not posting it could be the RAM. One continuous long beep means that there is no memory detected (D1-D4 may refer to the dimm slots 1-4). You can try booting off of a single stick of RAM, and try different dimm slots to get the motherboard to post.
Jul 15, 2012 | SuperMicro SUPER DP8-G2 (P4DP8-G2)...
SuperMicroX6DH8-xg2 no POST beep no Video I remove RAM and reseatd RAM but still no POST
If it's 1 long and 2 short beeps it's a video controller error. Check the warranty status and RMA if possible: http://www.supermicro.com/support/rma/
If it's 1 repetitive long beep, it means that no memory is detected. Try booting with only 1 stick of RAM. Try different dimm slots to see if you can isolate the issue. You may have a few modules that do not want to work together, a bad stick of RAM, or a defective dimm slot.
Mar 29, 2011 | SuperMicro X6DH8-XG2 Motherboard
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
Hi! I get Supermicro U2 server with X5DPA-GG MBO. Cpu and memor modules are ok, but when I turn on server I get long error beep. I took manual and saw that's overheat problem (or should be). But server...
This sounds like a video controller issue. Try booting with a different monitor. Ensure the cables are connected to the motherboard correctly (fans/power/led indicators). Try booting off of a single stick of RAM. Otherwise you may need to check the warranty status and RMA the motherboard to have it repaired/replaced.
1 beep: circuits reset - ready to power up
5 short, 1 long: memory issue
8 beeps: video adapter issue
Feb 21, 2011 | SuperMicro X5DPA-GG Dual Xeon/E7501/FSB...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
SuperMicro SUPER DP8-G2 (P4DP8-G2) Motherboard Logo
320 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
