Question about Poulan Garden
Where is the spark plug located on a poulan woodshark 1800
rockitman187
  • 2559 Answers
SOURCE: Do I mix gas and oil for a poulan woodshark 1950 chainsaw?
yes
Posted on May 01, 2009
Editor925
  • 285 Answers
SOURCE: spark plug location for Poulan 2300
Most likely to be found under the removable casing at the top of the chainsaw. The spark plug will have a black rubber spark plug boot which will identify its location. Remove the spark plug wire/boot to access the spark plug. The boot should just pull off. The spark plug will need the correct size socket to remove it.
Posted on Jun 15, 2009
  • 246 Answers
SOURCE: I have a Poulan Woodshark Model 1850. It starts, runs for a few
Try fresh gas with correct oil mixture. Carb might need cleaning and adjustment. Also try leaving chock closed and see if it runs longer before dieing...if it does, it indicates that it's not getting enough gas which could be solved with the carb cleaning and adjustment.
Posted on Jul 29, 2009
  • 636 Answers
SOURCE: poulan woodshark 1950 gas to oil ratio
Thats and old saw, you have to run those very rich usually 20:1
Posted on Aug 12, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Poulan Woodshark Model 1950 and the oiler
1) Check the oil holes in the bar to make sure they are not plugged. The bar can be mounted either upside down, or right side up, so make sure to check both sides.
2) With the bar removed, start the saw and watch for oil to come out of the side of the case/body.
3) If no oil is coming out the side of the saw, inspect the oil pump worm gear and drive spring. The spring is driven by the chain sprocket/drum. The clutch will need to be removed to inspect.
clutch removal as follows
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Posted on Dec 01, 2009
What could cause chainsaw not to start. It's not getting fire to the plug
If there is no spark it could be an HT wire or the magneto or the magneto grounding switch.
Oct 14, 2014 | Poulan Garden
My poulan woodshark model # p3314wsa bogs when I start to cut how do I fix it runs fine when not cutting
Remove the muffler, and check the spark arrestor to see if its clogged with Carbon. Clean it by either wire brushing the carbon, or heat the spark arrestor with a propane bottle torch, and the carbon will burn off.
Nov 17, 2013 | Garden
I have a poulan woodshark i traded for a old tv it has great compression and great spark but it wont start i think they might have messed with the carb what should i do thanks
Turn the carb adjustment screws all the way in and then turn them 1 full turn out and try that. If it starts it will probably require some fine tuning or some tweaking to get it to start. I also suggest you clean and kit the carb just to you know it has a good diaphragm and no clogs
Jan 17, 2013 | Poulan Garden
My Poulan Woodshark 14" type 2 (-2 on serial
Fuelleaking from the cap will not stop it running, 40-1 with good quaility two stroke oil shoule be fine, if there is a good spark and fuel at the plug, you need to check that the piston has not picked up, the hottest part of the engine is the exhaust side, so remove the muffler, and take a look at the piston skirt throught the open exhaust port, any signs of scuffing and it will need to come apart to check the damage.
Oct 11, 2011 | Garden
Where is the spark plug located on the 1800 woodsman model
I'd guess it is under the clutch cover aft of the muffler. That's where I'd look. HTH
Lou
Oct 15, 2009 | Poulan Garden
My polan 14'' woodshark will not start. i changed the spark plug and ignition modual but i dont seem to be getting any spark
Try this it is most likely shorted wiring between the ignition and start switch.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. HTH
Lou
Sep 06, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Aug 03, 2009 | Poulan Garden
Garden Logo
143 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
