Question about Garden
Just bought one used, the first time that we used it, it worked fine until it ran out of gas. Now that we filled it up we can not get it to run. We also accidentally left it out during one rain as well.
  • 7,482 Answers
Hi jesusislo900...
I do not believe the rain had anything to do with the mower not running.
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I was running it for the 1st time after this winter it was idling fine at high idle 1,200 rpm and i bumped the throttle and it ran really rough and will barely run at all, I just don't know what went...
sounds like it might have varnished gas in the system. I would change the fuel filter, clean out the lines with a good carb/fuel injector cleaner and fill the tank with fresh gas. I will run a little rough until the bad gas is run out. If this dont correct the problem then it might be in the fuel pump or fuel regulator areas.
Feb 28, 2011 | Chevrolet Corvette Cars & Trucks
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
Preventive Maintenance?
Should fog the engine before storage, this ensures that carb components are well lubricated. Drain leg oil and replace oil, Drain fill plug are both the same , you will have to pump the oil in the leg until it comes out of the vent hole. Should be fine, may run a little rough the first while until the rotten gas gets replaced with fresh fuel.
Aug 13, 2009 | Boating
Car won't start without adding gas to air intake then won't idle
Check the fuel filter, you may have clogged it when you filled the tank.
Mar 15, 2009 | 1989 Audi 90
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
