Question about Kenmore Microwave Ovens
721.63769300...f9 error - Kenmore Microwave Ovens
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Error f9
test the switch see the diagram attached. and fix it. God bless you
F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. f61ed0e1-8427-42af-957f-bae526341299.jpg087ce7f3-2365-4dd0-b6ad-246ebf8dcc6e.gif
Dec 09, 2013 | Kenmore Microwave Ovens
Error message F9
make this steps and fix it. God bless you
F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. 8c1bad79-df18-4ad1-b7da-f5627cf6859e.giffb8f574c-0f03-404c-916a-434180fb5662.jpg
Sears microwave m/n 721.63663300, displays F9 code ,what does that indicate?
The F9 error code indicates an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Dec 23, 2011 | Microwave Ovens
A code F9 appears periodically what does that mean
The F-9 error code indicates a defective control board, inverter or line voltage too high.
You can also visit the link to troubleshoot the issue.
http://www.ehow.com/how_7987910_troubleshoot-code-f9-kenmore-microwave.html
Mar 03, 2011 | Kenmore Microwave Ovens
F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 06, 2008 | Microwave Ovens
F-9 Error after running a few seconds...
If this is a "SmartWave" branded microwave oven then F9 is an error that indicates an inverter board or magnetron has failed. Either way.. Try this...With the F9 error cleared, start the oven and listen for a ticking sound. The inverter will attempt to 'fire' the magnetron 5 times.(ticking sound). If can hear ticking, replace magnetron....Else in may be a door switch problem
May 30, 2008 | Microwave Ovens
Kemore microwave model number 721.63763300
has failed. With the F9 error cleared, start the oven and
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
F9 error code
F9 is caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 26, 2007 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
67 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
