Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Error Code on DCR22E E:61:10 Code comes up immediately recording starts screen turns black & turns off. Any clue how to solve this or has this died?
  • 67 Answers
1) this is lance problem ,the error 61:00 shows lance error
2)open your camera body carefully
3)you must be careful when you remove the cables of lcd and other one
4)now you see lance asambly , remove the lance asambly and clean contact properly and fix it back
this will 99.99% help you to remove this error otherwise tell me more i will solve your problem
thx for reading
Posted on May 28, 2011
How to set up new hard drive DTR 6400T free view recorder
Try this;
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. No output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode.
http://forums.digitalspy.co.uk/showthread.php?t=1028520
The hdd is formatted as it is needed, much like a Mac. It uses RAW not NTFS, FAT etc.
Dec 08, 2016 | Computers & Internet
So i ordered a new power supply board for my LG 55la7400 television set...part was a perfect match..it went on smoothly with no issues whatsoever. Still just comes on and then black screen
Is it the same as it was before? If so You may have replaced the wrong board, but chances are if tv has a back light it's the problem. It would prob. be cheaper to have a tech. fix it the long run. You might try youtube videos they might help solve your problem. With electronics today their cheap & they don't last long.
Nov 10, 2015 | LG 55LA7400 55-inch 240hz Cinema 3D Smart...
I have error C0000034 applying update operation 460 of 41831 (generalize XML). All I did was turn my idea pad on. It never resolves and I have tried turning my laptop off and restarting. Any ideas
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions.
Dec 23, 2014 | Lenovo IdeaPad Computers & Internet
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Error code is display & not start the machine normally, error code is E000001-0002 ,please solve this problem ?
Try pressing Setting, *,4,5 then Enter.
If the Error code goes away thats great, but if it keeps coming back you may have a more serious prob that would require a serviceman.
Aug 23, 2010 | Muratec MFX-2830 Black and White Copier
Blue screen of death comes up then the netbook turns off
This article may help you....or these.
If you can turn off the auto restart to get a stop error code from the blue screen, that will help you to diagnose this error. See 'disabling restart..." here. Then reboot and note the exact error code reported. Write back with that info and we'll help you to sort it out.
You can look up codes here.
Also helpful links for blue screens here, here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 01, 2009 | Acer Aspire One AOA110-1588 Notebook
Power loss
i think there was a re call for this car & there was a problem with ignition switch. i was searching on other forums for the fix. i got a fix that there is a problem with ignition switch. so just try & replace ignition switch which would not cost u more than $100. Try it & post if your problem is fixed. Also if u have any othr solution then also fix this problem.
May 22, 2009 | 1999 Honda Accord
Power loss
Check the Fuel Pump.
May 04, 2009 | 1994 Honda Accord
Toshiba D-R560KU Fails to record. Error message E-21 E-4 E-4 54037380 Time Schedual starts then fails almost immediately. Using Sony DVD+/-RW disks. Tried from new disks from several different stores.
I read your return email solicitation to me to pay you before any indication that you even have a clue as to how to solve my problem nor even a guarentee should you not be able to. My solution is to block any further emails from your bogus service.
Apr 14, 2009 | Televison & Video
How do I solve a system error E000
You have to get into service mode and reset it under Funcation. You may have a power problem with your outlet. It could also be a problem with the fixing unit..
May 23, 2008 | Canon imageRUNNER 1023N Black and White...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
221 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
