Question about Goodman Heating & Cooling
Blower comes on ,no flame most of the time,but when flame comes on it only lasts for a few minutes then stops. light flashes 4 times,i have replaced primary limeter to no avail.?
  • 413 Answers
Your sensor is dirty. The sensor is the little rod that sticks in to the flame. It is just a little bigger around than a pencil lead and has one wire connected to it. It will be mounted just a few inches from the ignitor glow coil.
Turn power off to furnace
Take the sensor off
DO NOT wash it.
Take emory cloth or very light sand paper and lightly brush the steel rod of the sensor
You can also use a fine wire brush.
Put it back together and fire the furnace up again, chances are you've fixed your problem
Posted on May 28, 2011
We turned up the heat at our 5 year old cottage. Our furnace comes on and the blower starts up, the igniter glows and the gas starts the flame but it runs only for a few minutes. Then the gas stops and the...
There is a thermocouple that holds the gas valve open as long as there is a flame. This part will wear out with time. Look for a copper colored small tube that runs from the gas valve into the fire box and ends up at the burner close to the flame.
Oct 11, 2013 | 2012 Toyota Corolla LE 4-Speed AT
Fires and runs for a few minutes then shuts off tries to re fire a few times then goes to 2 blinks=cannot sustain or detect flame.
There is a flame sensor located in the last burner that lights up. It is either not seeing flame or not getting flame to it within a certain time. Check the wire that comes from it and goes to the circuit board for a bad connection. Check any ground wire connections for a bad connection. Pull out flame rod (sensor) and polish it with a scrub pad or soft wire brush. If none of these recommendations help, replace the flame sensor. Make sure the flame travels to the last burner, if not, clean the flame tray that allows the flame to go from one burner to another.
Feb 13, 2011 | Mr. Heater MHU75NG
Pilot light will light, burner & blower comes on for a few minutes, pilot & burner go out, blower stays on.
Sounds like a bad or dirty flame sensor. Look for a sensor located in the flame of the very last burner that ignites. Take a toothbrush and scrub it a little. Then try again. Do not scrub the igniter as it is very brittle.
Feb 11, 2010 | Heating & Cooling
Furnace ignites when thermostat calls for heat, runs for a few minutes and the burners extinguish, repeats... changed flame sensor, nodifference, saw 4 quick red flashes evry few seconds after burners...
You don't say if the blower is coming on, no blower would cause the limit to open. By the way, the limit is internal and auto-reset, not the manual reset roll out switches on the burner assembly.
Jan 11, 2010 | Goodman Heating & Cooling
I have a goodman gmp100-4 gas furnace and the gas comes on but shuts off in around 30 seconds, then tries again and the same thing... can i get some help please?
On the last gas venturi tube there should be a flame sensor located in the flame to prove it exsists, if its coroded the spark can,t jump back thru the moisture molecues in the gas to prove it has a flame to tell the circuit board to keep the gas comming. Just reomve the flame snsor and sand itand replace itback. T. Y. V. M.!
Dec 01, 2009 | Goodman GMS90703BXA Heater
Four flashes on Goodman GDS80904BX circuit board
I have this clunker-4 flashes is an open high limit code according to the wiring diagram and fault code sheet. the common denomonator for this furnaces problems is the circuit board. Always flashing 3, 4, 7 times most of the time having nothing to do with the problem. The actual problem is the board it's self. take it off the mounts (POWER OFF FIRST AND SWITCH OFF>)
remove from the 4 mounts one at a time then check the back of the board. you will probably notice brown spots on the green. this is where the board has burned up. replace the board and you will be fine, you will also be the 100th person I know to have this problem. Make sure you take a picture of the board before you take all the wires off so you can put them back properly. I personally have replaced the board twice the first replacement I purchased (warranty) was made by the same company as the original, the second board I replaced 1 year later with a new board made by a new manufacturer. they obviously knew there was a problem.
http://hphotos-snc3.fbcdn.net/hs066.snc3/13331_1198507328519_1403584043_30566732_3667503_n.jpg
this is a picture of a board another fixya user sent me today after he had the same problem as you and I told him what to look for. look familliar?
Nov 30, 2009 | Goodman GDS80904BNA Open Flame Heater
When Spa heater is turned on,Fan comes on but burner never lights
this is typical of a dirty flame sensor.your model does not have a thermo couple.remove sesor and clean with steel wool or fine emory cloth
May 11, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Ignition failure code on
Sounding like a flame proving device is failing to sense flame. Try to clean the device with some steel wool. It is located right next to the last burner looks like a thick wire. Take the steel wool and gently rub the carbon that has built up off. Should only take 4 or 5 strokes. Let me know it that did it. Ken
Nov 30, 2008 | Coleman Propane Forced Air Heater...
Coleman Evcon no fan when in heating mode
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Nov 30, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
