The camera has been working fine for over a year, but occasionally seems to just stop working. Usually switching off and on is enough to wake it up, but now is different.
When I switch on the power, the red light comes on, goes off, flickers and then goes off and the green light doesn't come on, and camera doesn't work.
-   my BL-C20 also worked good for over a year. One day, it found it not work. Evening pressing the reset switch, it flash red once, then never go to green.
Repeat a lot of time. same result.
Check the IP, it does set to the default xxx.xxx.x.253. but it does not turn out any web page.
unable to access the camera page.
~_~-   vincentma
Normal
0
Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Warning: This server is requesting that your username and password be sent in an insecure manner...
(More)
Warning: This server is requesting that your username and password be sent in an insecure manner (basic authentication without a secure connection) I get this message when I try to login to my domain name for my BL-C1A
Lost CD with Install file. DOes anyone know the location where I can download the file. Panasonic...
(More)
Lost CD with Install file. DOes anyone know the location where I can download the file. Panasonic has not returned email request to locate such a download, not on support site, which is good with all other documents and FW updates which I have... .EXE file Install file Installation FIle Install CD
port forwarded the port that is given by the camera Bl-C131 but still can not approach my camera....
(More)
port forwarded the port that is given by the camera Bl-C131 but still can not approach my camera. Camera status says :Camera installed correctly.
