Question about Makita 12 Volt Cordless Drill/Driver Kit
110volt makita drill reversible, how to remove chuck
  • 710 Answers
Hi, jsehlin,
Either put the drill in a vise or clamp it down with the chuck sticking out.
Open the chuck all the way and unscrew the retaining screw inside by turning it "clockwise".
Put the short end of an allen wrench in the chuck and tighten it down as you would a drill bit. Hit the long end of the allen wrench that's sticking out with a hammer so you are turning the chuck counterclockwise. This will loosen it so you can twist it off by hand.
Put your new chuck on and open the chuck fully. Screw in the retaining screw "counterclockwise". The chuck will seat itself during the first use.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 28, 2011
I have a MAKITA MODEL 6011D I got the screw on the chuck out, its a reverse threaded screw. How does the chuck come off?
in the tip section there are detailed instructions on how to remove a drill chuck.
Sep 21, 2011 | Makita Drills
I have a makita dp3720 drill, i can't remove the chuck. what gives
Not the chuck apparently, This could well be reverse threaded, many drills are, some aren't. There is generally a screw in the bottom inside of the chuck and then the chuck itself can be threaded on.
Jun 25, 2011 | Drills
The keyless chuck on my Makita HP2071F Drill (mains supply) is damaged. How do I replace it?
Open the chuck up fully, and in the bottom there is a reverse threaded lock screw that needs to be removed. (drill it out if you have to, it can be really hard to retrieve). Insert an allen key into the jaws of the chuck and hit the handle with a hammer to turn the hole chuck anti clockwise, firmly and quickly. Replacement is reverse but not so dramatic. Sometimes the chuck is damaged in such a way that it will not grip an (large) allen key sufficiently. You can then peel of all plastic parts of the chuck to expose the core. From here you can weld a metal pice to the chuck in place of an allen key. Take care not to damage the threaded axle from the gear.
good luck
Feb 25, 2011 | Makita & 1/2 Inch Drill
How do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Jul 31, 2010 | Makita Drills
How to change drill chuck for makita hp 2040
if its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Jul 31, 2010 | Makita & 1/2 Inch Drill
Removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Feb 19, 2010 | Makita 6408K 3/8" Variable Speed,...
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
I need to remove the chuck on my Makita 6213D drill
I am commenting so this will go out of the active section. When you put the chuck back on just reverse the procedure and hit it a couple times to seat the chuck and reinstall the screw.
Jan 15, 2009 | Makita Drills
Makita 12 Volt Cordless Drill/Driver Kit Logo
63 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
