Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Bad sector problem - Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
  • Western Digital Master
  • 27,725 Answers
You could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
Posted on May 28, 2011
All sector is bad after diskwipe. how to repair ?
If all sectors are bad it is time to get a new drive. Having bad sectors means that it will never hold data reliably. If all sectors are bad chuck it in the bin. It is a liability
Jun 01, 2015 | Toshiba MK5075GSX 500 GB 2.5" Internal...
Repair bad sector hard
BAD SECTORS
When a hard drive has bad read/write sectors it means the magnetic oxide layer on the disc platters are failing. Before you made an image of the hard drive you should have ran Error Check on the C Drive. This checks and locates the bad sectors and moves the data to an undamaged part of the disc platters and then locks out that bad sector so data cannot be written on the bad sector.
I recommend you do a fresh Windows install on your new hard drive to fix this problem and install the laptop's device drivers plus your programs and data before the hard disk fails completely.
Apr 07, 2013 | Dell Latitude E6500 Laptop
I have bad sectors in my hard disk what should can i do?
There is nothing you can do about bad sectors. The Hard Drive itself, with its associated electronics, automatically maps these bad sectors and doesn't use them any more. So, the answer to your question is "NOTHING". Bad sectors may eventually make your Hard Drive unusable, and if your bad sector count is growing quickly it's time to do a complete backup and replace the drive.
Mar 30, 2010 | Computers & Internet
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Buffalo hdd itb with bad sectors
Bad sectors ona drive is normal. The modern High capacity drives actually have more capacity than they tell you so that when bad sectors appear they swwap them out for good ones. So I would not worry about it, unless there are lots. How did you discover the bad sectors?
Go to http://www.grc.com and download spinrite. That will have a good go at fixing the bad sectors.
Jun 03, 2009 | Buffalo Technology (USA), INC. - 500GB...
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
BAD SECTORS
Your hard drive is divided into bits called sectors. When these sectors start to go bad, that means that the computer cannot read or write any data on those sectors. You cannot remove bad sectors and once you start seeing bad sectors it is a sign that your hard drive is about to crash permanently so you need to replace your hard drive and make sure you back up all ofyour important data immediately.
Jul 06, 2008 | Computers & Internet
How to remove bad sectors from hard disc
I have used Spinrite 6.0 with great success. I highly recommend it! It is an investment of about $80, but will repay itself many times if you are trying to recover data (which I have done from bad discs) or 'clean up' bad sectors permanently. It is the best program I have found for this, and I have tried many,
Jun 20, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
16 bad sector
Scandisk(or whatever) should mark those sectors as bad, thus preventing them from being used. But no, you cannot erase them, they are physical areas of your disk that cannot properly hold data. Bad sectors are not uncommon, and nothing to be alarmed about, but a loud hard drive is...
Mar 01, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
Hdd bad sectore problim
bad sectors are not fixable as far as hard drives go.
you mmight find software that claims ti fix bad sectors but the claim is false as they only temporarily overwrite the sectors and unmark the bad and remark to good but the problem remains to be the sectors are bad.
The best thing to do is to replace the hard drive with a good used one or a new one.
Sorry but as a technician I know what bad sectors are and what happens when you get them.
Jan 22, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
131 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
