Question about Safe International U.S. Patrol JH558 Hidden Wall Safe
How do i Install the us patrol hidden wall safe? it came with no instructions
How do I install a Sandleford Genie, key operated safe? No instructions with package. Has two attachments with nuts and washers. To be installed into a wall or floor.
I usually install into a cavity wall which means you cut out a template.in eternal wall preferably in a built in cupboard or wardrobe which is less likely than behind a picture frame.then chisel out the dimension of the safe to allow 1/4 inch more space.open the safe and make provisional marks for raw plug positions.i always use engineering raw plug and bolts as these will withstand greater force.then use socket extension to tighten up ...the internal wall to external cavity is usually a minimum of 6 inches if it is all brick but if internal is block then you may be able to house something deeper.hope this is of help.you may find YouTube tutorial on this and some builders merchants offer online tutorials on most DIY projects.
Feb 05, 2015 | Home Security
Stanley instructions
Try using a magnet instead. Move the magnet back and forth against the wall, slowly... until it sticks to one of the ferrous screws hidden in the sheetrock. These hidden screws are holding the wall board/sheetrock onto a stud.
Magnets! Free stud finder! and no batteries to replace!
Aug 26, 2014 | Stanley 77 500 Intellilaser Pro Stud...
Is there a factory reset for protex wall safe pws1814e
refer to the manual that came with the safe it will have a master code included or instructions on how to reset the unlock code or you can contact a lock smith or the manufacturer and they will be able to assis
Apr 29, 2014 | Safe International Protex Wall Safe...
I have had my Secure Logic biometric wall safe for 4 years and my battery does not charge. Where can I get replacement batteries? And how do I install them?
The instructions for the device contain information about how to open the battery container and how to replace them, located here
Look on page 16, "Maintenance Instructions"
It appears, from this document, that it only needs a regular A size 12V battery.
Dec 23, 2012 | Computers & Internet
Bunker hill safe model no.45891 bought used, can't open. any ideas?
Safe has Key lock hidden on it? Contact Harbor Freight with serial number, to try and get new key. Once opened follow these instructions at:
http://www.harborfreight.com/manuals/93000-93999/93575.pdf
Oct 20, 2009 | Check Point Network Adapter
How do i install a magnetron tube in my JVM1653SHO3 microwave
There are a ton of screws to remove...
You'll need to pull it from the wall, and it's easier if you still have the installation instructions.
If not, you can download GE owner's manuals and installation instructions here.
I recommend two people to pull it down due to the weight and awkwardness.
Next remove the outer cover, then you'll see the various screws you'll need to remove to get it out.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 19, 2008 | GE Microwave Ovens
Safe International U.S. Patrol JH558 Hidden Wall Safe Logo
57 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
