Question about Video Game Consoles & Games
NINTENDO NES FRONT LOADER POWER LIGHT FLASHING RED WITHOUT AND WITH GAME IN LOOKS LIKE NEW 72 PIN CONNECTOR INSIDE BOUGHT RECENTLY HAVE NOT SEEN IT WORKING YET IF NEW CONECTOR WHAT OTHER FAUL COULD IT BE PLEASE ADVISE
  • 4 Answers
You should open your nes and disable the regional lockout chip.
NINTENDO NES FRONT LOADER POWER - a911e61.jpg while in there, check the connector and 1) if it is new, make sure it is properly connected to the board, or 2)if its old, use a very small eyeglasses flathead screwdriver to pull pins closer in (1mm-2mm) to a uniform level.
Posted on Aug 17, 2008
SOURCE:
Nes pink screen no blinking power light
Try cleaning the game packs out with autopsy and rubbing alcohol to see if it helps
Apr 04, 2013 | Nintendo NES Console
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
My Nintendo NES just keeps flashing on and off and the screen is flashing yellow. i opened the console up dusted out with compressed air. then i tried to fix the connectors on the 72 bit loader by pushing...
Rather than try to bend the pins back into place, you may have more success replacing them with a new 72 pin connector. You can find several merchants online that sell them.
Mar 07, 2011 | Nintendo NES Console
My NES_oo1 powers up, but does not do anything when I press the Reset botton. Looks like the machine does not recognize the game cartridge.
Did you try blowing in the game? That used to work for me. I would look into buying a new 72 pin connector. This issue has plagued the NES and this new 72 pin connector fixes this problem for good. Just google NES 72 pin connector.
Mar 06, 2011 | Nintendo Video Game Consoles & Games
Nes wonnt turn on, but when it does red light is flashing
Did you replace the 72 pin connector while it was apart? This is the number 1 reason for NES to fail to load or flash. A brief search of "72 pin connector" on eBay should net you a new connector for about $5 US.
If you have already done this, and the problem is really bad then recheck your work and make sure everything is connected tight.
Also consider that allot of nes games were not taken care of very well, so if the problem is specific to a couple cartridges, consider cleaning them as they are probably not connecting well.
Good luck.
Apr 02, 2010 | Nintendo Super NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Mar 31, 2010 | Nintendo NES Console
Nes power light oes on and off
The nes does this to stop people from playing pirated games, but it can also be because the game cartridge or console is dirty. Try cleaning inside the game cartridge with a cotton bud dipped in a cleaning product of some kind. it mostly works for me!
Jul 09, 2009 | Nintendo NES Console
Nes flashing black and white and making a horrible sound
a 'front load' nes ALWAYS does this, even if the connector pins inside the console are new. the cartriges on a Front Load nes rarely completely seat, as Nintendo redesigned the Famicom very poorly for the US market. try this 1. put the cart in as usual, but hold it all the way down 2. slip an unwanted/extra cart in on top of the metal hoop above the cart your using. this gives a better contact for the cart. try cleaning the cartrige pins as well. some won't read right if there's ANYTHING on the pins.
Dec 03, 2008 | Nintendo NES Console
Porblem with my recently purchased nes
Make sure your tv is set to the correct input mode. Also, if the power light is flashing with a game in it's because the 72 pin connector for the games in the console is dirty and worn out. You need to install a new one AND clean your games. Dirty games will just transfer dirt to the new connector.
Jul 29, 2008 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
Video Game Consoles & Games Logo
165 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
