Question about Compaq FP 7020 17" Flat Panel LCD Monitor
After being on 3-4 min it shuts off and imediatly turns back on
I turn on my computer the monitor works for about 4 minutes maybe a little longer than it shuts of like the power was cut but the power cord seems to be working ok any suggestions
  • Compaq Master
  • 5,568 Answers
The power cord isn't the only path the monitor needs. The connection between the system and the display can have problems.
With the power off: I would at least pull the signal cable and re-plug it several times to see if the problem leaves.
If it still shuts down, (power off again) open the system box, touch any part of the unpainted chassis metal to discharge any static buildup you might have; locate the video card (if it isn't an on-board chip), remove any screw holding the card in and rock the card in its slot to wipe the contacts, press back into the slot, replace the screw removed and try again.
Since the problem could also be caused by a dead backlight or the power supply for it, try to view at various angles to see if there is anything discernable on the screen.
If you can identify any content, then it is the backlight or supply.
Depending on your skill and the construction of the monitor, replacing the fluorscent backlight is a possible home fix.
If the high voltage power supply has failed, this is an item for a tech.
Posted on Aug 16, 2008
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Fan quitting on unit
Maybe the room is dry enough so the humidity sensor is turning it off?
If not, maybe the thermisensor(fuse) on the fan motor is failing?
Jan 02, 2010 | Comfort-Aire BHD-501 Dehumidifier
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Samsung syncmaster 206bw turning on and of, light flashes on for 4 seconds, then off for 2 repeatedly i can see windows is working fine in the background during the 4 second gaps while the monitor is on...
If you have soldering iron and can place an order at DigiKey.com (and are willing to get your hands down on this), this is a rather easy fix with some direction. You basically will be replacing some failing capacitors inside the unit.
Jun 16, 2009 | Samsung 206BW Monitor
Monitor shuts off during use
3 years old and generally rated as a Mediocre monitor to begin with, I'd say I'd invest in a new monitor
Here are some replacement options:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010190020%201309821311%204017&name=%24100%20-%20%24200
Sep 10, 2008 | BenQ FP72G+ 17" LCD Monitor
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
LCD Monitor power problems
yes the monitor is over heating there should be warranty on the montor
Dec 15, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Compaq FP 7020 17" Flat Panel LCD Monitor Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
