Question about Canon PowerShot SX100 IS Digital Camera
Connection from the camera to the computer: powershot SX100is
  • kakima May 28, 2011
    Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 06, 2012
fotomohamed
  • 321 Answers
SOURCE: My Camera (PowerShot sx100is) says the card is
inside the camera small pin is there its stuck send for service to us by courier
Posted on Jun 18, 2009
SOURCE: Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Posted on Jul 16, 2009
  • 668 Answers
SOURCE: What is greatest dpi for PowerShot SX100IS?
Yes your camera will give images with 300dpi . You need to set the dimension as 3264 x 2448.
Hope this helps.
Posted on Jan 30, 2010
  • 102366 Answers
SOURCE: memory card protected impossible to use the camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 23, 2010
  • 2385 Answers
SOURCE: I have a canon powershot sx100is The lens is
Hello
You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
hope it helps, if not take camera to the technician, if so
DO RATE THE SOLUTION
Good Luck
Posted on Jan 01, 2011
What is the maximum size sd card can i put in my Canon Power shot SX100IS
SD cards max out at 2GB. The SX100IS can also use SDHC cards, which max out at 32GB.
Jul 22, 2011 | Canon PowerShot SX 200 IS Digital Camera
I lost my installation cd for my cannon sx100is camera. wat must i do to install my camera to my computer
Greetings - Your Canon does not need any installation software to connect to your PC. You plug it in, it gets recognized and you can move, copy, delete photos, etc.
If you would like to get the software that came with your camera (for manipulating photos and such) you can get it HERE.
Happy photo snapping and thank you for using Fix Ya.
Mikeywaf
Apr 26, 2011 | Canon PowerShot SX100 IS Digital Camera
Unable to get pictures from canon powershot sx100is camera even after installing solution disc
Having received no response to my query in over two months, I assume my suggestion to use a card reader solved the problem.
Feb 07, 2011 | Canon PowerShot SX100 IS Digital Camera
I want to down load drive of the canon digital camera powershot model sx100IS
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/other_powershot/powershot_sx100_is#DriversAndSoftware
You might want to consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 27, 2010 | Cameras
How to restard canon powershot sx100is
Restart means to turn it off and then back on.
Aug 08, 2010 | Canon PowerShot SX100 IS Digital Camera
I plug in the camera into my computer and hit the
Solve your problem by using a card reader instead of your camera.
Jul 10, 2010 | Canon PowerShot SX100 IS Digital Camera
Hope this helps.
Jan 30, 2010 | Canon Cameras
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
