How do I remove the glass faceplate to clean the glass for the meter on my McIntosh MC501. I also want to adjust the fiber optic's so both of my 501's McIntosh logo's glow at the same intenscity one is brighter then the other the meter's glow at the same intenscity. I looked inside a little and all the led's are working I thinf it is just an ajustment ofthe fiber optic strands themselves. Thank you
  • 19,396 Answers
Hi.
To clean the glass you need to take apart the whole thing. Disassembly starts from screws at the bottom. once the front panel is out you disassemble the front panel to reach the glass from behind.
Regarding the optic fibers, those have no electronic inside. Their functioning is purely based on physical principles. If one fiber is dimmer than the other, then it is either damaged inside, or not placed in the correct way in the assembly.
Here the full service manual. Disassembly diagrams (exploded views) are available at pages 15 and 16.
Regards.
Ginko
Posted on May 28, 2011
How to get optical to work
You hear about fiber optic cables whenever people talk about the telephone system, the cable TV system or the Internet. Fiber-optic lines are strands of optically pure glass as thin as a human hair that carry digital information over long distances. They are also used in medical imaging and mechanical engineering inspection.
In this article, we will show you how these tiny strands of glass transmit light and the fascinating way that these strands are made. Fiber Optic Patch Cables
May 01, 2014 | Hitachi 43UWX10B 43" Rear Projection...
Fiber optic plug does not connect
Optical fiber connectors need to be clean in order to work properly, they need some special cleaning tools, you have to ask for them at the electronic store, normally you should avoid disconnecting and reconnecting fiber optic connectors a lot.
Apr 05, 2014 | Samsung HT-Q100 System
Internet phone
Optical fiber is just a transmission medium just like the copper, you should not worry about your phone, if everything goes well it should be working better than ever with high speed data capability as a plus, just think of the optical fiber as your ordinary cable but is made of glass instead of copper.
Apr 01, 2014 | Panasonic KX-T7630 Corded Phone
Hp colour laserjet 2820 keeps coming up with error 5. i've turned off and then on but keeps coming up with the same error. is it the bulb?
Step1: Open flat bed galss & optical scanner assm, clean flat bed glass, as well as clean internal reflecting glasses in optical scanner, ensure that don't use any kind of cleaners to clean the reflecting glasses, use ear buds to clean gently..Step 2: Replace optical scanner assembly..
Oct 24, 2011 | HP LaserJet 2840 All-In-One Printer
Scanner Error 5
Remove flat bed glass take out optical scanning assembly(detach flat cabl & belt).gently hold the unit & remove bannet of the unit care fully clean the reflecting glasses with ear buds gently. fix it back & clen flat bed glass both surface with glass cleaner fix every thing back,take care of finger prints not to print on glass, check if not resolved replace optical scanner assm.Note:technical skills & patiency required to do this process ..Best of luck
Oct 11, 2011 | HP LaserJet M1522nf Multifunction Printer...
Color copying gray turns out magenta. this happens when copying from glass only , printing from workstation it's ok..
try to run auto gradation adjust press * with head then go to adjustment/cleaning and follow the instruction or check the optical mirrors for dust contamination if is dirty you can remove 2 screws and remove the glass then wipe all the mirror with lint free paper or cloth( do this first before running the gradation adjustments)
Jul 15, 2009 | Canon imageRUNNER C3200 Copier
Adjustment for light copies on a xerox m20i
You will need to do a couple of things, 1 remove, disassemble the scanner and thoroughly clean it, and while you have the scanner out, remove and clean the laser.
The toner cartridge may also be defective. that metering blade in that cartridge fails and causes light images also.
If you need instructions on how to remove and clean the scanner and laser let me know, I will type them out to you.
Not hard, just time consuming.
If you print out a report how does that look? If prints look fine and just the copies are light, then the mirrors in the scanner head a re probably fogged up. All the plastic in that scanner causes that same film on your scanner optics as you develop on your car windshield. Same process.
Jan 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Use scanner copies print not solid
Clean the optical path. Remove glass and use very fine quality micro fiber cloth with no cleaning agents to wipe mirrors and glass. reassemble and test. If no better then maybe focus is off!
May 29, 2008 | Ricoh Aficio AP3800C Laser Printer
Canon PC-940 Copier
There are no fiber optics in the copier. It has 6 mirrors that send the image to the drum unit. Did you try to clean the copyboard glass? Also, do the marks move up and down the page? Also, have you replaced the drum cartridge recently? Pull the drum unit out can you see track marks on the drum it self. If not I would have to say it may be comming from the fixing ass'y, the hot part of the copier. Try to use a dry rag and wipe up any loose toner in the paper path then try to run some blank pages in the copier this may clear up the problem...
Mar 04, 2008 | Canon PC-940 Black and White Copier
329 people viewed this question
 Grubhead
Grubhead
