Question about Toshiba Portege M800 Notebook
The dvd driver doesn't work. I downloaded it again and still doesn't work. I downloaded finalmedia player but it doesn't work properly either. It doesn't give me subtitle options in one dvd movie and it doesn't recognize most others.
  • 21 Answers
Did you check your DVD player program setting?
What about DVD region setting for? (If you use non-us DVD like PAL.)
Posted on May 28, 2011
  • Toshiba Expert
  • 560 Answers
First open the "Device Manager" to check for any error messages related to the device and click on "Start" and select "Control Panel" .
Now double-click on the "System" icon then click on the "Hardware" tab and click the "Device Manager" button. A new window appears, and displays whether the device is working properly. If there are any errors, click the "Troubleshoot" button and follow the given onscreen instructions.
Check the DVD that you are trying to use to and ensure that it is free of dirt and scratches and the proper format compatible with your drive.
Now uninstall any drivers that may be on your computer from previous DVD drives.
Now download the latest driver updates for your DVD drive model from Lenovo website & install it.
Also check on Toshiba website that your machine has the minimum requirements to operate the drive.
Now restart your computer & check your DVD drive.
I hope issue has been resolved.
If the same problem is still occurring, get the reliable technical assistance at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba laptop and desktop problems.
Posted on Sep 20, 2012
Dvd medie player
It seems you don't have any codecs... The problem is not in windows media player.
Just install a codec pack like http://www.free-codecs.com/download/codec_pack_all_in_1.htm
Hope to solve your problem.
May 05, 2013 | Compaq Presario CQ56-115DX Laptop
Toshiba satellite laptop-a205-s5000 cd/dvd player doesn't work need help
Go to the Toshiba Website look for original drivers for the device.
Nov 04, 2012 | Toshiba Computers & Internet
Download cd driver for a gateway nv54 laptop
Your operating system shouldn't need a new driver for that. CD drives are recognized configured automatically. You can try cleaning the laser lens on the CD Drive with a CD/DVD laser lens cleaning kit. If that doesn't work then you'll need to replace the drive.
Jun 23, 2012 | Computers & Internet
Dell X590C drivers for win 7 64 bit
You shouldn't need drivers for that device. try cleaning the laser lens if it doesn't work properly. If that doesn't work you need to replace it.
You can get a great inexpensive replacement here:
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=5&name=CD-DVD-Burners&Order=RATING
Jun 19, 2012 | Dell X590C - 16X internal black 16X DVD...
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
I installed finalmedia player but it doesnt work,i can't watch my videos thru it.
Try getting Adobe Flash Player here:
http://get.adobe.com/flashplayer/
You have to be out of all apps when downloading so, it may be easiest to download to file, get out of apps, open file and download. E-mails that access the web will stop it also. You will also want the lastest version of Java. If you have Java, make sure it's updated and if you need it you can get it here:
http://www.java.com/en/
Jul 13, 2011 | Computers & Internet
Dvd will not play properly
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is not playing DVD properly.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again properly.
Good luck.
Jul 10, 2011 | Televison & Video
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
I bought a rebuilt Dell Latitude D620 laptop and it will not play dvd's.It tells me that I need to download a dvd decoder. What is safe and where can I do this
Hi lou_59,
Welcome to FixYa! How are you doing?
Are you trying to play DVD using Windows Media Player?
Download and install VLC Media Player, it is a Free Multimedia Player Software capable of reading most video and audio formats.
You can download it here:
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html
Hope that helps. Thank you for using FixYa.
May 03, 2011 | Computers & Internet
Open Questions:
Toshiba Portege M800 Notebook Logo
319 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
