Question about Honeywell Air Purifiers
Enviracaire model numbers 12500 and 13503 fan blades are wobbling and making loud sound.What is cause and how to or where to get repaired ? My zip code is 60142
How do I access the filter on a honeywell enviracaire 10500 air purifier
Hello, this is Ava with Think Crucial.
You may find your online instructional manual on how you can access the filter cage of your Honeywell model by clicking the link below.
Honeywell enviracaire 10500 Series Owner Manual Page 7
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 13, 2013 | Honeywell Enviracaire 10500 Air Purifier
My Honeywell Enviracaire Hepa Air Filter machine has a squeak when it runs. I am unable to find a place to oil it. Can you help?
is no place to oil it.They have closed type motors. You can just use a lubrificant typeWD40 to spray the mouving parts
Feb 21, 2011 | Honeywell Enviracaire 13520 Air Purifier
Sounds like the fan is making a loud noise
Probably all you need to do is oil the shaft. Remove the front grid, firmly but carefully pull off the fan blades, and use a thin household oil to penetrate down the shaft. Turn the shaft and repeat the turning until it loosens up. If that doesn't solve the problem, get in touch with us at fredandmb@frontier.com. We've been with the company 20+ years.
Feb 03, 2011 | Ecoquest Breeze AT Living Air Purifier
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
There is no ticking sound. Is my Enviracaire Elite working? I think I put the filters in when and had the button in the on position. how can I know if it is working?
1. Make sure the furnace or air conditioner blower is running.
2. Make sure the access door is firmly closed and latched. If door is not closed properly, an interlock keeps the air cleaner off.
Jan 26, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
UV100E Ultraiolet system. Noticedbulb not coming
Honeywell has a great team of technical support personell, just call the number on your owners manual.
Jan 14, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have the enviracaire f300e 1001 in a house i just bought. i cleaned the filters. whenever the furnace turns on a buzzing comes from the unit. is this normal? the thermostat also flashes "filter".
Sounds like the filter is damaged or has bent fins.Make sure all the fins are not touching eachother, or they will arch and keep buzzing and flashing.Also there is a wire on the incoming air side of the filter(between each fin) to precharge the particales entering the filter .make sure the wires are not broken.good luck--Nate
Oct 29, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Air Purifiers Logo
67 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
