Maxtor 1 TB One Touch 4 Plus. I install it but it does not show up as a drive on my computer. After a reboot, the windows XP-Pro "found new hardware" notification keeps showing up. New USB, New Firewire, different XP-Pro computer ... same errors.
    Scholar:
  • 133 Answers
Hmmm. Are you absolutely certain that you have the latest updates or service packs applied to your machine. Something in my mind reminds me of an update Microsoft issued to correctly identify and use these large capacity drives correctly.
Posted on Aug 16, 2008
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win...
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
Apr 14, 2017 | Maxtor QuickView (4r080l0-qv) 80 GB Hard...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Vista is not picking up my maxtor harddriver but wheni had xp was .
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
May 30, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Maxtor onetouch 4 plus its new should I format the drive?
Most likely you need to partition and format the drive, especially a new drive. Doing this all depends on your operation system. With Windows XP and Vista, you just need to install the drive a boot the computer. Locate the disk utility software thats built into the most newer OS.
Mar 20, 2009 | Televison & Video
Installing windows
1. Windows 2000 / XP maximum hard drive size 137 gigabyte limit
This one was fun. To install a hard drive larger than 137 gigabytes on your computer you need the following:
a motherboard, such as the Gigabyte GA-7N400 Pro2 which support the 48 bit hard drive addressing. Only new motherboards can be counted on to support this.
Windows 2000 service pack 3 or later. Windows XP service pack 1 and greater have this support built in. I assume this isn't a problem with Linux at all...
Shalom
Aug 25, 2008 | Maxtor Hard Drive
Maxtor one touch II
This doesn't require downloading anything, installing anything, or holding your mouth in a certain way.
1) Plug the drive into power and into your Vista PC's USB port.
2) When the 'Found New Hardware' wizard pops up, click the recommended option. When it says it can't find the drivers, select 'Show me other options', and then Browse your computer for drivers. Choose the C:\ drive, and click next.**
**The key here is that Windows Vista comes pre-installed with the drivers for the Maxtor external hard drives. So they're on your PC, even if the Wizard tells you they're not.
4) Wait a few minutes, and yo will see a window that reads, "The software for this device has been successfully installed," and now it will appear as a drive letter under 'Computer'.
thanks RP
Aug 18, 2008 | Maxtor OneTouch II 300 GB Hard Drive
Maxtor One Touch 4 Plus
I have the installation program. You can contact me
Email: haulingkc@yahoo.com
Tony
May 01, 2008 | Computers & Internet
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Pci ide raid card problem
Could be a PSU problem. What wattage PSU do you have?
Jan 31, 2008 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Computers & Internet Logo
David Payne
David Payne
