I had problems like evryone else not knowing that there was a lint trap that needs to be cleaned. thats been addressed but i have since had problems witht he machine pausing mid cycle...water pumps out fine...if you push start it will go again? the machine is not very old..i cant smell anything from the motor? is there a reset?
  • 4 more comments
  • maconeil May 28, 2011
    i am having trouble finding a model # other than it is a dora.....ive looked inside and out for it
    model is and adora....unit will pump water but doesnt seem to want to spin now
    model# GHDVH67OHBB
    Model # GHDVH670HBB
    this is a general electric washing machine model # is GHDVH670HBB...machine keeps pausing...it will pump out the water but will not spin while it pumps
    sorry i have checked the model # 3 times GHDVH67OHBB.....i am trying to run a load as we speak...load washes no problem and pumps the water.....but wont spin it and than it pauses the machine....keep pushing start and at the end the clothes are still soaking..i put it on an extra rinse and spin and it turns slowly and rinses but will not give it a proper spin of any speed. still the door or the board?
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
The problem seems to be with the timer that needs replacement. Please get back to me with its model# if you have any other questions.
Kevin
Posted on May 28, 2011
  • 4 more comments
  • Kevin White
    Kevin White May 28, 2011
    You have to check inside the door or at the door jamb to locate the model no
  • Kevin White
    adora is not a model# and as I have mentioned earlier the problem is either with the control board or the belt that is worn out and needs replacement.
  • Kevin White
    Thats not a correct model# for Whirlpool Dryer
  • Kevin White
    INVALID model#
  • Kevin White
    Alright if everything works fine and it just wont spin then the problem is with the door lock assembly thatneeds replacement
  • Kevin White
    The problem can be with the belt or the door lock assembly, you can test the door lock switch mechanism with a voltmeter before replacing it
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Is there a lint trap or lint filter on this washer? It is a kenmore washer model# 11022622100. I seem to remember my old washer having one inside the lip of the tub but I can not find one anywhere.
On most 110 mods there was what they called a lint trap at the bottom of the wash basket.You can;t see it without taking the basket out (ya I know dum) you will need special tool to remove basket.that filter has now been replaced by whirlpool with 4 little plugs and the so called filter is removed.You can clean the old one and unit will be fine..for that job I would say to get a pro as it takes me about 2 mins to open and will save you as a home owner a whole lot of headaches..Hope I helped and Thanks for voting
Just a note that whirlpool made that machine.
Mar 17, 2011 | Washing Machines
My eState dryer MOD: tedx640pq1 wasn't heating. I replaced the thermal fuse and switch to an indoor lint trap because I suspected that the vent was blocked. Now, the dryer is getting too hot, even on the...
do you clean the the indoor lint trap each time or is it the style you put water in to an bucket? It still has a problem with air flow as it is exiting the unit.
Feb 13, 2011 | Dryers
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Jan 08, 2010 | GE Washing Machines
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
My calypso machine leave alot of lint on clothing
you have to clean the lint trap before every use. I assume that you know that. also , you need to clean the area where the lint trap is really good, so you dont have a dryer fire.
Aug 25, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
WHIRLPOOL DUET HT IS TODAY NOT STARTING AND COMPUTER IS ON
i hope this helps it is the most common problem /solution for these washers. run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Mar 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
