Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wireless keypad was working and has stopped. I changed the battery and I still can't program it??
    President:
  • 3,197 Answers
Your keypad has failed.
Posted on May 31, 2011
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Model 1265-67 stopped working with the remote after I repleaced the drive gear. Nothing was changed but now the unitl opens and closes perfectly with the wall switch but I can't get the...
Make sure the light in the wall control isn't blinking. That would be an indication that the lock function is on. To turn it off, press and hold the lock button for 3 seconds.
Oct 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad 139.18795 does not work with sears garage door opener 53993d. What's the key to program it?.
Can't find 139.18795 anywhere but if you are trying to program an old keypad with a new opener it will not work. The radio frequency was changed in 2005.
Aug 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
My wireless keypad stopped working. I replaced the battery. It worked 1x and hasn't worked since. I'm able to program remotes. The keypad is backlit and flashes when I enter the code or try to program it....
I would make sure the battery contacts are clean and not corroded. Otherwise a new keypad is most likely the answer. Just FYI the keypad will still work when the wall control is locked.
Sep 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
We just moved in our house in January and our keypad on our 1/2HP Liftmaster stopped working. I have changed the battery and when I try the code the backlight blinks several times but the door never opens....
Try programming the keypad by doing this:
Press and immediately release the smart/learn button and then walk over to your keypad and key in any 4 digit code you like and press enter. If this doesn't work you keypad has quit.
Aug 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote works randomly,changed batteries now the
Keypad flashing is normal. Sounds like you may have a bad logic board. Try programming everything.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
I changed the battery in the key pad and now it does not work
Changing the battery should not cause it to stop working but you can try programming. Press and immediately release the smart/learn button and then walk over and key in your four digit code and press enter.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad will close door but open
WHEN YOU CHANGE THE BATTERY YOU NEED TO REPROGRAM THE UNIT.
IF THAT DOESN'T WORK YOU PROBABLY HAVE A BAD KEYPAD.
HOPE THIS HELPS
Apr 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
21 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
