Question about Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive
I can't get my laptop to recognize the mini drive when I plug it in
  • Hitachi Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 28, 2011
PC does not recognize G-Drive mini triple
Make sure your PC supports USB 3.0. There is also an On/Off switch available at the back. Do check it also.
If the problem still persists, contact the drive manufacturer here for instant support:
http://support.g-technology.com/support/g-drive-mini
They have manuals and troubleshooting guide there that'll help you in further exploring the problem and resolving it on your own.
Hope it helps!!
Feb 16, 2014 | G Tech nology GDM4 250 X 250GB G-DRIVE...
Driver for hp mini 1034-NR, because doesn't detect the hdd
Drivers for hard drives are automatically initialized unless you are setting this up as RAID. If your drive is not being recognized in a machine, plug it into another laptop or desktop or dock to rule out the controller or cable being an issue.
Enter your BIOS setup to determine if it's being recognized by the system. If not, your drive is most likely faulty.
Dec 11, 2013 | Toshiba MK6028GAL 60 GB EIDE Hard Drive
Hp mini black screen w/ cursor blinking
Sounds like the hard drive isn't working. check in the setup bios of the machine to make sure it is recognized as the main boot device. It should be second in order so that a flash drive could start it up if plugged in. It would be third if you have a CD which minis usually don't. If it lost the date/time and settings, the backup battery is bad and needs replaced.
Mar 13, 2013 | HP Mini Computers & Internet
My HP DV9740US laptop will only recognize one external hard drive at a time. When i plug in another external hard drive it'll make the sound that it's recognized but won't show up in My...
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
Jul 28, 2011 | HP Pavilion DV9740US Laptop
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
When i turn my laptop on it say no boot device enter boot device and press any key i havent got one could i reset my hp mini lapotop and start fresh with it?
The "no boot device" error is caused by the system not recognizing your hard drive. The drive has failed in some way and the laptop can no longer read from it. You will need to replace the hard drive before you can reload your laptop.
Mar 24, 2011 | Computers & Internet
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
My computer will not recognize my mini media
You can reset it but the easiest way to explain how to do
this is by getting the manual.
http://userguides.50webs.com/mini_media.htm
Aug 14, 2008 | Hasbro Massively Mini Media Player
Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive Logo
96 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
