Question about Latte Communications Mocha Bluetooth Headset
Wont pair with my iphone 4 - Latte Communications Mocha Bluetooth Headset
Why won't my new iphone 5s pair with my Cardo scala G9x? My iphone 4 pairs very easily.
believe that it is because the 5s is digital and the 4 is analog--we install blue tooth systems in cars and had to replace most of them because of the release of the 5s--older blue tooth system are analog so are not compatible with the 5s--as probably is what is your problem
Jul 27, 2014 | Apple iPhone Smartphone
Paring iphone 2013 huyndai elantra
I had no problem pairing my IPhone 5S. I was even able to pair my old IPhone 4. I tried the old IPhone 4 after seeing this post. what kind of problems are you having pairing the IPhone and what version is it? All I did was turn my Bluetooth on on my IPhone then i pushed the black hone button then hit the settings button on the phone screen then pressed the pairing button then pressed the add to button, once the phone is found it should show on IPhone as Elantra on the IPhone and put in the passkey that it shows on the Elantra screen ( factory default is 0000 ) then the screen in the Elantra will show pairing. then it's paired. then you can go through all the setting after the phone is connected. Just make sure before you get into the car your BLUETOOTH is turned on on your IPHONE or it won't connect till it is turned on and the phone won't connect while your foot is on the brake if you have push start.
Apr 21, 2013 | Hyundai 2013 Elantra Limited
Wont pair with phone
Hello
Please press the power button for 10 seconds then the indication will keep blue instead of flickering. Then you can use your iphone search this earphone.
Mobile Power Mall Solution
Feb 11, 2013 | Motorola Mobility S9 Headphones
Just bought a used 2004 with handsfreelink. tried pairing my iphone 4 to it by following directions with voice commands and 4 digit passcode. system wouldn't pair and can't get radio on in any mode(cd,...
When you try to pair your iPhone 4, what message does the iPhone prompt you after you enter in the passcode?
Have you tried making sure your iPhone was disconnected from any other headset around you?
Mar 07, 2011 | 2004 Acura TL
H681 wont' pair with iphone
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
Jan 09, 2011 | Motorola Mobility H681 Bluetooth Headset
My iphone 4 does not detect other Bluetooth devices. It keeps on searching of hours and days. Other bluetooth enabled devices detects and pairs with iphone but iphone does not connect with them.
Dear ito824mumbai,
iPhone will connect only with other Apple devices and only with Bluetooth headsets. It wont connect with other devices.
Regards,
Jan 04, 2011 | Apple iPhone Smartphone
When i try to turn on the bluetooth function on my 3gs it remains in the search mode- (the circle of death) forever and doesnt pair with my motorola H710! Help!!
it wont pair whatever you do. even if you install a photoshare app on your iphone, it still wont be able to transfer files to and from your iphone. the iphone's bluetooth only works with other iphones/ipod touch.
Aug 03, 2010 | Apple iPhone 3G
Have put bluetooth on but it wont paid with any
To your diappointment the Iphone cannot send photos, songs, or anything like that, yet. What you can try is restoring your Iphone and then see if you can pair it with your device. If that doesn't work, then it just means that the device you are trying to pair with it non-compatible with the Iphone.
Oct 27, 2009 | Apple iPhone 3G
Wont sync with iphone
Make sure that the headset and the phone are both are in "pairing" mode. Even though the iPhone's bluetooth is on you will have to select the headset from the phones bluetooth menu. To get the headset into pairing mode press and hold the "+" sign for 3 seconds. Hope this Helps!
Jun 08, 2009 | Apple iPhone 3G
Latte Communications Mocha Bluetooth Headset Logo
22 people viewed this question
Top Latte Communications Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Latte Communications Radio Communication Expert? Answer questions, earn points and help others
