I have a matsiu 14v2r and on the sreen a box has appeared with the letters ATS and it is not allowing me to change the channels or decrease the volume manually or with the remote. what do i need to do to solve this?
  • 19,396 Answers
Hi.
Matsui does not provide online manuals for older CRT models. As a technician I can get the circuit schematics, but that will not help to understand how to operate the TV.
Did you try disconnecting power cord to check if the TV does reset?
Disconnect power cord and check the antenna connection while power is off. Restart the TV with only antenna connected (no DVD, Video or other). If problem is still there when you connect back the power, try using the Source/Input selector button on the TV remote.
Posted on May 28, 2011
Dewalt DSCN1360 tuner problem
Don't you have an automatic tuning system or ATS? By pressing a band switch for a while the ATS starts looking for stations and stores the ones that have a good enough signal. Even if a station broadcasts but the location of the radio is not adequate for a good signal to be received, the station won't register and it will appear to you that the tuner is skipping.
Dec 02, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
We get a black box on some channels
Ur captioning is on.When u turn into the channel have captioning,that why u have words,or symbols.Check ur remote have a CC button.Press it make sure it off.U will not get anymore black boxes with letters or symbols.
Feb 27, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Screen has black box with greek letters on channel
If you put the TV on CH 3 and use a VCR (if available) to change channels you'll know if it's the TV or cable channel (sound like the channel)
Oct 05, 2009 | Televison & Video
Blue sreen with message sayin this is an encrypted channel
call Comcast and do nothing more. if they messed it up make sure they fix it or you could be out a tv and a cable box. if they wont then call the manufacturer of the tv.
Jun 01, 2009 | Initial HDTV-320 32 in. LCD TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
