Question about Singer Featherweight II 117
Need to load refill bobon and load heedle - Singer Featherweight II 117
  • 710 Answers
Hi spacey266,
I could not find an instruction manual for free. But here is the web address for the cheapest I could find... $10: >>>> http://www.sewusa.com/Sewing_Machine_Manuals/Singer_Manuals/117_II_FeatherWeight_Instruction_Manual_.htm
Copy and paste the entire address into your web browser and the page will come up for you.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 28, 2011
I am unable to refill the shuttle.the shuttle holder isnt going round.
Sorry but we really do need a make and model .perhaps a search on Google will find the information you need .
Sep 09, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
Celebrity 550 the needle dont pick up the threat of the bobon
You have forced the machine out of timing ! You need to either take it to a sewing machine engineer or look up how to adjust the feed timing on you tube ! Good luck
Aug 28, 2014 | Sewing Machines
The needle will not go up and down, seems to be frozen, what is wrong?
Can you move the heedle up and down by hand and is the motor running? If yes, is the clutch for the bobbin winder not disengaged?
Feb 06, 2011 | White Sewing 1418 Mechanical Sewing...
Needle won,t pick up bobbin cotton
You may need to retime the machine, email me and I will attach instructions drivewithken@blueyonder.co.uk
Mar 08, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
I've lost the manual to the Singer Tiny Tailor mending machine M100A and need to know how to refill the bobbins. Can you help me? Thanks
Jan 18, 2010 | Singer Sewing Machines
I have an older Husqvarna sewing machine (sle 6570
In the middle of the bobbin winding spindle, there is a piece we'll call a "flange". It is spring loaded but sometimes sticks. When it is in the center of the spindle it diengages the sewing machine drive system that drives the needle. Make sure it is not in the center of the flange. You can use a small screwdriver and gently press the flange outward and hopefully you may hear a small click and everything will be fine. Make sure also that the round plastic piece the flange is located in the center of, is pushed all the way to the left, (in you're sitting in front of the machine) if you pull that round platstic "knob" to the right, like you're trying to remove it from the flange, it will pop outward and engage the tranmission for sewing heavy fabrics.
Oct 14, 2009 | Husqvarna Sewing Machines
How do i refill a bobbin 7 thread machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To wind a bobbin, guide the thread from the spool post to the small round tensioner /guide on the top of the machine.Wind a few turns of thread onton the bobbin.Place the bobbin on the bobbin winder post. Release the hand wheel and wind the bobbin as full as you like or until it stops. Remove the bobbin,place it in the bobbin case and insert the bobbincase into the hook.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Apr 29, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer Featherweight II 117 Logo
20 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
