Question about Imperial IFS40 Deep Fryer
I JUST BROUGHT THIS IMPERIAL DEEP FRYER AND I WANT TO CHANGE FROM NATURAL GAS TO PROPANE GAS.
  • Imperial Expert
  • 683 Answers
You will need a conversion kit from natural gas, most of this kit contains gas valve spring, burner and pilot orifice. Check the nearest authorized dealer in your area and ask buy the appropriate conversion for your fryer.
Posted on May 30, 2011
Does the Elite EFS-40 have a built in regulator?
Thanks for the Question! If you are referring to a internal Gas regulator this model comes with a option for Natural Gas or Propane.
So you will need to make sure that you have to correct gas connection for the Fryer. If you look at the Gas valave it will state whether it's NG (natural gas or LP liquified petroleum).
So if a NG valve it must be connected to Natural Gas. and Vise versa.
Installing a NG Fryer to propane will result in a dangerous situation because of the pressure difference.
If you are requesting information for a different type of regulator please let me know and I can give you the information you need.
Thanks for using Fixya.com I hope this answers you question.
Oct 14, 2013 | Imperial Kitchen Appliances - Others
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Want to change natural gas to propane
You need to change the regulator,gas valve and burner orfices and possibly the pilot.If you have a commercial fryer go to 3wire.com and you will find the part's you need.Any questions?
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Imperial IFS40 Deep Fryer Logo
303 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
paulcarew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
