Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
Hi i have the Bose Companion 5 speakers for more then a year now i have been playing them for over an hour and just realised that they keep fading the sound goes high and low i have never experienced this problem before im using a macbook pro laptop not a pc if someone could please advise me thanks
I just bought companion 5 1 month ago and am facing this same problem from 1st week. its an embarrasment. i had given it to the service center and they could not detect the problem. so i did my own research and found that if i kept a fan blowing on the rear vents of the acoustimass module the problem does not occur.you also please check it. i have again given the acoustimass module to the service center and told them this lets see what they do???
Posted on Jun 12, 2011
Bose repair
Does not seem very complex. I think it is because of the broken fuse. Simply Open the back part of Bose companion 5. The Circuit board attached to the back part is basically for the Audio output socket, Control pod Connector and Power supply connector. on the Left hand side of the board you will find a fuse soldered with the board. most probably that fuse is broken. replace the fuse if broken or just connect both end of the fuse with thin wire (temporary) to check. Hope it helps.
I am outta home or else i could have added an image for you. maybe tomorrow.
Thanks
Jun 23, 2014 | Bose Companion 5 Multimedia Speaker System...
Hi i have the Bose Companion 5 speakers for more then a year now i have been playing them for over an hour and just realised that they keep fading the sound goes high and low i have never experienced this...
if you are refering to your computer speakers
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 28, 2011 | Bose Companion 5 Multimedia Speaker System...
Hi _ I got a new set of Bose Companion 5 - is working fine with my PC Windows Xp service pac II. suddenly the speakers go off wehile playing music & I have to restart the comp to hear music ?? Cant...
Try another set of speakers to eleiminate the BOSE speakers as being the issue (even cheap ones will do). If the problem does not re-occur, the issue is with the speakers.
If all the speaker jacks are plugged in correctly, I would consider returning this set, as it looks like the issue is within the circuitry of the Woofer
Jan 01, 2011 | Bose Companion 5 Multimedia Speaker System...
My speakers keep muting themselves at random
I am having the exact same problem. Has this been resolved yet?
Feb 12, 2010 | Bose Companion 3 Computer Speakers
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
"This device has no output controls" Bose Companion 5 problem!
Metal detectors/ Xray devices have been known to destroy magnet based electronics (speakers). This could be your problem.
Sep 22, 2009 | Bose Companion 3 Computer Speakers
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
332 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
