Question about Keurig Platinum B70 Coffee Maker
How do I reset the menu - go back to zero settings
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote about how to registeryour Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
KeurigRegistration, User Manuals, Cleaning, and Troubleshooting heatman101
Posted on Sep 05, 2011
  • Irongamer Dec 15, 2012
    These are useless btw. I have a B70 which has auto shut off set. The machine turns on and say "not ready". It then turns off after about 2 minutes. Pressing menu does nothing. Lifting the handle up and down brings up the cup size but again the menu button does nothing. None of the examples on fixya help and most of them reference B66 which has different buttons which are not on the B70.
Samsung SPL220 lamp reset
Using your remote press the MENU button. Navigate to the system settings to reset the lamp back to zero. If you don't have a remote you'll have to navigate the menu using the projector buttons.
-GWOOD
Jul 14, 2014 | Samsung SPL220 Projector
Canon MP130 - warning keeps coming up that the 'waste ink absorber is nearly full. What do I need to do to correct this, thanks for your help.
Hi Teasel850,
There is an internal counter that prompts this message. There is software to reset the counter called MPTool. But why complicate things when it can be reset manually using the following steps.
Reset Canon Pixma MP130 Printer
  1. Turn on the printer.
  2. Press the MENU key, and then SCAN, COPY and SCAN again - entered the service mode.
  3. Select NVRAM ACCESS further OK.
  4. Select SET ABS-M LEVEL and set value equal to zero.
  5. Select SET ABS-R LEVEL (if any) and is set to zero.
  6. Turn off the printer POWER button.
Best regards
Mike
Jan 30, 2011 | Canon PIXMA MP130 All-In-One InkJet...
My canon pixma mp130 is coming up the waste ink absorber is almost full , how do i fix this , can i do it myself?
Two possibilities of solving this by yourself.
First solution: Clean the absorber pads
Look inside the printer, while the ink cartridge seated on the right side of the printer, under the ink cartridge is two absorber pads. Open the cartridge cover, to position the cartridge carrier in the middle. Leaving the right portion open and expose the absorber pads. Lift it up using a tweezer. Now clean this pads on a running water. And when its clean return it back to its place. Close the cover.
Second solution: Reset the Printer after cleaning the absorber pads.
These are the steps to reset your printer and clear all the errors including ink absorber full.
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
7.
8.
9.
Do this as many times until it fully reset the printer
Please give this solution a 4 thumbs up to help me improve my ratings.
Thank you for using Fixya.
Sep 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full
http://www.youtube.com/watch?v=VVpjqBr7KjU
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
thats how it is done on that printer, you need to look in the manual to check for yours.
Mar 26, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is almost full,so printer has
Hi there
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
3. Into the service regime
4. Select NVRAM ACCESS and further BY OK.
5. Select SET Abs- m level and advance value equal to zero.
6. Select SET Abs- r level (if there is) and also you will establish into zero
7. You will turn off printer by button POWER
Some time of other you will need to clean out the inkpads that are in the printer or it will in time leak the ink out.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink Absorber is almost full
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
PRINTER PixmaMP 130
HI
You can try.
All best
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a Pixma MP130 and I am getting the message "ink absorber is almost full". What do I need to do
1. Start Printer
Dec 15, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Pixma 130 waste absorber is full
1. turn on.
2. Press MENU, after SCAN, COPY and again SCAN - your are in a service mode.
3. Change NVRAM ACCESS and press ОК.
4. Change SET ABS-M LEVEL and set value to zero.
5. Change SET ABS-Р LEVEL (if this function not hide) and set value to zero. If this function not presents, go to next step
6. Turn off printer by a power button.
Thats all )))
Jan 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Motorola format
go to MENU then SETTINGS then INITIAL SETUP then MASTER RESET (000000) OK.
Nov 10, 2008 | Motorola Mobility L6 Cellular Phone
Keurig Platinum B70 Coffee Maker Logo
234 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
