Mitsubishi WD-82738 has no picture, makes short whirring sounds but won't turn on. Flashes 6 red lights then 1 yellow light and repeats sequence. Tried system reset but to no avail, light turns green for 15 seconds but then goes back to flashing red and yellow light sequence. Menu will not display. I'll be having a service tech coming to check it out but curious if you have an idea of what the problem could be?
  • Willie Howell May 29, 2011
    the flashing lights give a error code; check again this flashing. the flashing red is the first number in the code. you said that it was flashing 6 times then you said yellow flashes once. i have consulted this model service manual and have not found a code 61 for this unit.
  • Jerry Perkins Dec 20, 2011
    Did you ever get this problem figured out I have the same with my Televisionand they(Mitsu support) said a six one does not exist either. Any help would be appreciated
    Genius:
  • 1,030 Answers
After rereading the symptoms you descibe what you describe might be a faulty colorwheel. When the set is first plug up there is a small mechanal motor that has to reach certain speed. if this does not reach that speed the set will not allow the lamp to fire. The whirring sound could be the colorwheel trying to spin up. these break all the time. (its a motor and anything that moves eventally will not.) it a fairly simple rep;air thatn most quilfied techs can repair. Such a repair generally should take more than a hour to do
Posted on May 29, 2011
Mitsubishi DLP LED Trouble Code 6 Red, 1 Yellow
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 16, 2017 | Mitsubishi Televison & Video
What is wrong with Mitsubishi tv Model WD:82738? I just replaced the lamp and it is making a sound like a bearing rubbing and the picture is flickering.
It sounds like your color wheel is going out. Here is the part#. If you do not feel cofortable with this type of repair, please have a servicer do it for you. Good luck to you.
May 23, 2016 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My mitsubishi wd82738 starts normally green light flashes and then stays on,i get sound and blurred bars that are barely visible
Probably a lamp problem. They aren't very expensive and relatively easy to replace. If not the lamp, possibly the color wheel. If it makes a high pitched sound from time to time, it's definitely the color wheel. Good luck
Aug 26, 2014 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
WD-82738 82-Inch six red blinks one yellow blink replaced chip to fix white pixels issue.
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Blinking code detail, and fault finding procedure to many brand TVs are given. Pull up older posts.
Nov 29, 2013 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Mitsubishi tv wd-82738 no power
Most of these TV's have switched mode power supllies that run very hot. There is a likely chance that the capacitors have cooked (burst) on the PSU board. They are common capacitors. Open up the TV and with the mains electricity turned off, check the 'X' on top of the tubular capacitors. If they are bulging, rather than flat, then unsolder them and replace them.
I've repaired many of these sets because of this problem.
Nov 16, 2013 | Mitsubishi WD-82738 DLP TV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
Televison & Video Logo
288 people viewed this question
Top Televison & Video Experts
