Question about Lexmark X1150 All-In-One InkJet Printer
Ink cartridges where can i find a replacement clip?
  • 876 Answers
Here is the link to order a part
https://parts.lexmark.com/wpo-catalog/US_en/
Have a good day!
Posted on Aug 16, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 16, 2008
    Did this solution work for you? Please rate my solution .
I replaced the ink cartridge and it won't print now, message says cartridge may have been installed incorrecty
Remove ink cartridge and make sure you have removed any tape that could be covering the gold contacts, also check your printer to ensure the area where the cartridge clips in is clear...When replacing the cartridge you should hear a defined click, this is usually a good indication that the cartridge has been installed correctly.
Also make sure your are installing the correct cartridge in correct position
Sep 10, 2017 | The Office Equipment & Supplies
How do I install the ink cartridge
You will find two buttons on your printer.
One for power and the another is a function button.
Push them together at the same time while the printer is on.
In most cases this will move the ink head to the center on the machine in order for you to remove the old ink cartridges and install the new ones. However a different button may need to be used consult the manual in this regard.
The ink cartridges are clipped in, you will need to undo the clip!
Then pull the ink cartridge out, usually upward force applies.
Now once the old cartridges are removed you can install the new cartridges.
Be sure to remove any stickers that are meant to be removed, read the sticker and if it says "remove before use" then remove it.
Insert the cartridge and push them down, then the clip is to be clipped in.
Now to get the ink head to move back to it's lair first try pushing the function button.
If nothing happens then push both buttons together again.
Please read this session a number of times to get the jist of what needs to be done.
Also I would like to ask you to please rate this session with the use of the Thumbs on the right.
Thanking you very much.
Till next time!
damnor01
Mar 20, 2011 | Canon Pixma iP2600 Photo InkJet Printer
How do you remove printer heads on cx3200
The two clips that swing down and hold the ink cartridges can be easily removed without breaking anything or removing screws. Look at the hinge points and use a screwdriver to gently pry one hinge of each clip out and the clips will simply lift out. But after that there are 2 small screws that hold the print heads in that ink cartridge carriage. Remove them and keep track of them. The white clip positioned in the color ink cartridge bay helps to hold the ribbon cable in place, but once you see what will move in regard to the print head, you can loosen the white clip and the print head should lift up. In this way, conceivably, the CX3200 print head should detach from the ribbon cables (there are 2) and a new one goes in its place. I'm dealing with a friend's CX3200 that the black is not printing and I'm cleaning it out and finding a lot of dried sticky ink. Probably used until dry or refilled the cartridge with the wrong type of black ink.
Apr 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
How do you take out the ink box out of a Epson Stylus NX400 printer?
Usually there is a clip that releases the ink cartridges. You have to lift up the scanner unit and the ink cartridge will move to a position where you can remove it. There you will see the clip that holds the cartridges in place. Pull it back and lift up. You will now be able to remove whichever cartridge you want.
If you are replacing the ink, insert it and press gently until it clicks and then push the clip back into place.
Close the scanner unit and you are finished.
Thank you
Lolita
Jan 18, 2010 | Epson Stylus NX400 InkJet Printer
INK CARTRIDGES ALL NEW. SAYING THEY ARE EMPTY
Hi, i think during the process of changing the cartridges, the top lid on the ink cartridge that clips or keys the cartridge down inside the printer has been broken and needs to be replaced.
I suggest you get a technician to help get a replacement for this. With this your printer should be in other.
Jan 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Broken clip for black ink cartridge
Unfortunately, this is not an easy fix. To replace the ink cartridge holder, you would have to dissasemble the whole Print head/Carriage assembly. The when you put it back together , there are timing factors to be set. With printers so inexpensive, I would opt for a new unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 31, 2008 | HP DeskJet 5550 InkJet Printer
Im tying to replace my ink cartridge
Open the scanner bed/door. The Inks will center automaticly. Then squeeze the clip at the end of the ink cartridge to remove the ink cartridge thats empty. replace ink and click it back into place.
Do a deep clean and calibration of the printhead.
Jun 25, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark x2480
what do i do when i lift the cover of the printer and the cartridge does not slide over and therefore i cannot change the ink cartridge?
Feb 22, 2008 | Office Equipment & Supplies
Ink Cartridges
You should be able to open the printer below the scanner. The printhead should move to the center of the printer. Then you open the clips holding the cartridges and remove the old. Replacement cartridges click into the same slots. Then you secure the clips and close the printer.
Jan 28, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
