Question about Amana Kitchen Ranges
Amana range going from propane to gas what do i need to d0?
    Master:
    Sergeant:
  • 385 Answers
It's best to check with your gas company. Sometimes they will do it for free.
Posted on May 28, 2011
What do i need to convert my amana self cleaning range to propane
convert it from what? if it is natural gas to propane...you would need to swap out the burners.
Oct 26, 2010 | Kitchen Ranges
The oven flame comes into the oven around the oven bake cover and all burners and broiler have a perfect flame. this is a brand new oven
Are you on natural gas or propane? If you are on propane did you have it converted form natural gas. Due to the difference in orface size you will be getting more gas flow then needed. If it was converted you need to contact the store and advise them it has a possible gas valve problem.
Jun 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
Can I replace the natural gas jets with propane jets?
Hello. Yes. This is commonly done. You will need the conversion kit suited to your brand and model. Contact your propane provider as most times, they have these kits in stock.
Nov 20, 2009 | Amana AGDS902 Gas Kitchen Range
IWANT TO CONVERT TO PROPANE
It's probably not quite as easy as everyone says. Most gas appliances use a different control valve for LP (propane) and natural gas. You most likely will have to eplace the control valve with an LP one. I would contact Amana to see if they offer a conversion kit -- it would probably come with detailed instructions.
Nov 17, 2009 | Amana ACS3350 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Converting to natural gas
hi tom,
here is the service manual for your convenience.
http://www.servicematters.com/maytag_library/docs/S231_2R1.pdf
please start with page 28 and follow from there.
please let me know if you need further assistance.
thanks
Sep 26, 2008 | Amana ARGS7650SS Gas Kitchen Range
Problem solved! I found the instruction sheet. Thanks anyway.
Aug 19, 2008 | Amana ACS3350AS Gas Kitchen Range
Gas Range Oven use without electrical power
It will be necessary to change the top burner orifices when converting to propane. You should be able to light the top burners with a match or lighter, however, the oven will need proper operating voltage.
May 22, 2008 | Amana Ovens
Kitchen Ranges Logo
41 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
