Question about Coleman 9928A50 Propane Grill
How to clean the grill and drip pan and get the grease and burnt on grease removed without hurting the finish on grill, lid/cover, drip pan, and the heat element
    Brigadier General:
  • 4,736 Answers
If you have a great amount of caked on grease build up, using a plastic putty knife is a good way to go. It won't scratch the finish and will remove the lion's share of the grease. Follow that, by scrubbing the remaining residue with a wet sponge and Simple Green in a spray bottle (it's biodegradable and won't hurt the finish.? Spray the Simple Green on, wait a minute or two and wipe of with a wet sponge. Rinse the sponge often Do not wet the heating element/burner. Use a grill brush to gently remove any any residue. Actually, it's best to remove the burner to clean it, because it also gives you the opportunity to clean the Venturi valve. As far as the drip pan is concerned, the plastic putty knife will work there too. In the future, lining the drip pan with aluminum foil, will eliminate having to clean it.
The grill grates can go in the dishwasher. Just do not allow them to go through the dry cycle.
My best advice on keeping a grill clean, is stay a head of the cleaning. Not allowing grease and residue to continue to build up. I say this, both as a grill dealer and as an avid professional grill-er.
Hope this has helped you. Please let me know and Happy Grilling!!
Posted on May 28, 2011
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site FAQ
"My Unit Goes Out On Smoke
  1. Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
  2. If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
May 29, 2015 | Traeger Industries BBQ070 All-in-One Grill...
How do you empty the drip pan located under freezer side of side by side
Older side by sides had a removal drain pan behind the grill located under the doors in front. Remove grill and just pull out the pan carefully to empty. But the newer refrigerators have the drain pan built into part of the compressor mount and are not removable. You can't empty or clean them without removing the back cover at the bottom back of the cabinet. You would need a sponge or towel to dry up the water.
Mar 21, 2015 | Refrigerators
How to remove and clean grease pan on Vermont Castings model 608SB
The drip tray is accessible from the rear of the Grill. It is necessary to lift up the pan slightly while pulling it out. Or depending on how old your VC grill is, it may be located on the left end of the grill (you should see a small handle). In which case you pull it out and was you reach the end of the drip tray, lift it up slightly to remove it.
TIP: To make clean up of the drip tray easier. Spread a thin layer of Speedy Dry (It's what NASCAR & garages use to soak up oil) on the bottom of the drip pan or tray. You can purchase a bag of it, at any auto parts store, When it comes time to clean the drip tray or pan. Just remove the tray or pan and dump the used Speedy Dry in the garbage. Then, spread a thin layer in it again. Actually, because the Speedy Dry absorbs so well, you'll find that you'll only have to dump the tray or pan occasionally.
Hope this helped you and Happy Grilling!!
Jun 23, 2011 | Grilling
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
I have a Weber E-420. When the lid is closed and it rains, I find the dripping collection pan full of water and overflowing, resulting in a real mess of water and drippings all over the inside of the...
That's not unusual at all. Nor, is it a design flaw. The are are air vents all along the back of the grill head that allows rain to get in. Especially, blowing rain. The best solution is to either bring the grill into the garage when it's not in use OR if you don't have a garage, invest a few $$ in a good quality grill cover. Not some cheap $9.99 special. Either one, will solve the water problem, as well as keep the tree drippings and bird droppings off the grill.
Apr 19, 2011 | Weber Summit E-420 Gas Grill
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
Grill drips grease on counter.
lol, ours does that too, we raised the rear of the grill up so the grease didnt roll under the grill and onto the counter. try that, i even think the new ones come with feet extentions to change the angle
Jan 15, 2010 | George Foreman GR26CB XL Indoor Grill
Terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Jan 05, 2009 | Maytag MSD2656G Side by Side Refrigerator
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Gas grill overheated
I might have an Idea to what happened. All grills have a drip pan, most all new grills have a drain for grease that falls from our savory meats. Well, if, (not saying that you haven't) but if, you have not cleaned the drip pan, there is still grease left over that gets absorbed by food droppings. IF this is the case, you had a ticking time bomb of a grease fire. The grill did not overheat, the grease caught fire. You said your grill was a year old; so the regulator did not go full blast and when they do go bad they do not let gas pass through.
Not trying to preach to no one because I have done it myself, never leave your gas grill on and unattended. I hate to say it but even the owners manual says it.
I hope I did not come off the wrong way and I hope this might give you an idea/thought of what happened.
Sep 26, 2008 | Thermos Stainless Steel Gas Grill
Coleman 9928A50 Propane Grill Logo
231 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
