Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
I have a Frigidaire dishwasher, model # FDB1050REQ2. It does not do anything right now and I am thinks the computer board is not working, but need to know if it might be something else or what?
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Posted on Jul 17, 2010
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
Frigidaire dishwasher model FDB520RHS2 will not advance pst wash- just keeps washing draining and refilling the wash. does not advance. Left it run for 3 hours, still wash only
We had a problem with our dishwasher, it just went crazy one day and lights would light up but ours did not wash or anything...anyways upon further investigation found out by taking 6 large round head screws off,, the handle and outer cover came off, then there was a cover that was covering a circuit board and this was the brains of the washing machine, ordered the part from sears 160.00 and washer is all set. good luck. oh ya, upon further exam. when I took the board off could see discoloration on part of the circuit board. this means burned out resistor or fuse.
Mar 22, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher model pldb998ac1
If you use salt, maybe that needs refilling. Can't think what else would be low
Nov 08, 2017 | Dishwashers
Frigidaire dishwasher model # FPHD2491KF
It seems like you are experiencing a faulty door latch and control board communication. This would need to be diagnosed by a technician and the correct part(s) replaced.
Aug 29, 2012 | Frigidaire FPHD2491KF Dishwasher
Frigidaire dishwasher model # FPHD2491KF stops at about 102 or 103 and the water stops coming in. I have to trip the breaker once or twice to get it to work..what is wrong?
Sounds like the unit has a faulty timer or bad communication from the control board to the timer. I personally would contact a tech if this continued or a different alpha-numeric error code is displayed.
Jul 23, 2012 | Frigidaire FPHD2491KF Dishwasher
Frigidaire dishwasher will fill but wont do anything after that, if i hit cancel it will empty, how do i fix that?
If the unit will turn on and fill but won't advance to the next setting/step then either the unit's timer is faulty or it is not communicating correctly with the control board.
Jul 21, 2012 | Frigidaire Dishwashers
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Dishwasher is stuck on rinse and hold
I had the same problem, just today!! Reset your dishwasher... with either the fuse or the breaker... I did it and it works just fine now. Good luck. No need to buy anything just yet!
Dec 18, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher won't start up
this could be a problem at the electrical hook up ,also could be a open door switch or if there is 115 volts to the control board and nothing happening then you need a board.
Nov 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
42 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
