My Ricoh aficio MP 171 shows "contact service SC542" I can't get into service mode to reset anything... Thanks
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
Ickoajnc
  • 183 Answers
SOURCE: service mode
Press the “Up/Down arrow” keys together for about 5 seconds, and then press the
“OK” key.
“SYSTEMver x.xx/ 1. Service” appears on the display.
The machine automatically goes off line when you enter the service mode.
enter SP 5810 and reset the SC 543 **** if again appears please do not reset it again because you may do bigger problem and damage more part than ware damaged in first place .
The SC code says that the termistor is damaged so check on the fusing unit dose the termistor is standing in good position or has dirt on the surface of he termistor.
RATE ME IF THIS HELP YOU
Posted on Jul 17, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
How to empty ricoh mp171 waste toner
mp 171 has no waste toner container. it recalculates toner back to developer section.
Mar 20, 2017 | Ricoh Aficio Mp 171 Spf Copier,...
Why ricoh aficio mp 171 spf is showing servical sc 542?
because in some moment the fusing temperature was more high than the optimal. maybe it is just because of precaution issued the SC542. or maybe is problem . you need to reset the SC542 by entering the service mode. for this if you call service they will charge you big money. so if it is just issued just as precaution by doing the following procedure the machine will work fine again. but if the code do not clear do not repeat the procedure more than ones that you can make bigger damage that it has have before the code. so follow the next procedure: first enter service menu by pressing the following keys in order. press the yellow clear key the pres 107 and then press the red clear/stop key until on he screen write service menu or something other than the usual screen. after that appear. turn the machine of by the left side switch and wait 5 seconds, than turn it in again. if starts to work everything is okey . if the SC542 appear again do not repeat the procedure. call a serice techician
Oct 18, 2016 | Ricoh Office Equipment & Supplies
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
SP mode and SP Codes of Ricoh Aficio MP 2001L/2501L WITH ITS SERVICE MANUAL
Hi There,
if you want all the codes you have to download a service manual from the internet or get it from a Ricoh technician, is there a specific code you are looking for? the most common one is code 5 810 to reset error codes.
Jan 16, 2015 | Ricoh Office Equipment & Supplies
How to reset error sc 582
sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
Jan 02, 2015 | Ricoh Aficio MP-C4000
How to enter service mode in ricoh aficio mp 161
Service mode is 'Clear-1-0-7-stop (hold stop until machine goes into service mode).
Aug 22, 2012 | Ricoh Aficio MP 161 Black and White Copier
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
2,143 people viewed this question
jasbo
jasbo
