Question about Polk Audio PSW505 Subwoofer
The amp board on my psw505 powered subwoofer burnt up while the sub was not even in use. I just recently put a new replacement woofer in the box since that to fried a few weeks before the amp board went out. I was curious if there was anywhere you could recomend me to that sells new amp boards or refurbishes fried ones ?
5 Suggested Answers
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
lynchms
  • 93 Answers
SOURCE: best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Posted on Feb 12, 2009
  • 189 Answers
SOURCE: The electronics board has 4 resistors fried and I
You probably turned on the amp at full tilt and that is the safety for you speaker check out an tv shop and see if they can get the info or order you a new board .You can order the schematics from a tv or electronic appliance place if you give them the info and do it yourself. Go to the store or website and check out what color of resistors they have or just order the board direct from Polk or an authorized dealer.
Posted on Jan 10, 2010
Grubhead
  • 5449 Answers
SOURCE: Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Posted on Jan 17, 2010
I have a single 15" sub woofer in a box it was
Simply put, burned voice coil. Either too much power can do this or not enough power with distortion. solution- if the sound is clear then its too much power- turn the amp down. If the sound is distorted and raspy- its not enough power and your getting distortion-get bigger amp.
Jan 07, 2013 | Car Audio & Video
I need a replacement sub woofer for my LW 12
Polk Audio PSW505, BIC America F12, Hsu, SVS, Outlaw, Axiom Chane Subwoofers
Sep 03, 2012 | Cerwin Vega LW12 Subwoofer
I recently picked up the THC-c60 system without the supporting amplifier. Can I still use the subwoofer and the speakers without the amp? I note that it also came with a DIN cable, is there some way to...
You can use the sub-woofer and the speakers even without a supporting amplifier. The sub-woofer alone is powered with 167w per channel enough to power all the speakers. The DIN cables used to connect the sub-woofer to any source device like a computer, multi-media projector and others.
Dec 02, 2010 | JVC TH-C60 System
This isnt actually an alpine problem, but i am having trouble getting power to my c4 subwoofers. my amp is working fine and when i put my other subs in they work fine. when i put these new subs in they...
make sure if the amp work at 1 or 2 ohms you need to setup the same in the woofer.chek if the woofer is 2 or 4 ohms dual voice coil and how the amp work better
Sep 25, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
2002 Ford Explorer Sport - Blown Subwoofer
yes you can replace it but is gonna be costly,because your gonna need a box plus the new woofer,any after market will not fit plus will require more power ,so your gonna need a bigger amp,plus wiring etc,,,,,re consider using a factory sub again or replace the sub plus the amp..check the replacements and amps at crutchfield..good luck
Jul 10, 2009 | Car Audio & Video
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Sub woofer keeps blowing fuses
NO dont try a 3 amp fuse.It is made to BLOW if there is a problem. That sub is not worth fixing, JUNK it. There are a lot of problems with it. Such as heating up and melting the board witch could cause fires. Thats what happened to mine. Like I said JUNK it and buy a different one.
Nov 19, 2007 | KLH ASW10-120 Subwoofer
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
Polk Audio PSW505 Subwoofer Logo
357 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
