Question about Foxconn 6627MA-RS2H Motherboard
Hello. I need some help with my mother board. I can not start my pc. when i turn it on it stays on the black screen. i've tried removing the clock battery but still have the same problem. the part number is FOXCONN 15235
  • Foxconn Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Posted on May 28, 2011
  • 1 more comment
  • Brian Sullivan
    Brian Sullivan May 28, 2011
    even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
    a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
  • ahernande322 May 28, 2011
    i've cheked all , and seem to be alright. The fan is working , all of the leads are well connected. The electrical power on my office suddenly shut down. i dont have a no bracker my pc turns off so since this happend the pc just stay stuked showing on screen the pc Manufacturer's name and ask to pres ESC or TAB to enter to set up. Is it anything else i culd try to fix it?. i've read on your webb site there's something to do with the Jumpers can you show me how does it works?
  • Brian Sullivan
    ok during the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    or
    During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
    Also you might try
    Turn Off the computer, now as soon as you hit the power button, keep on holding “Alt” key & keep on tapping “F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
    hope this helps
Dell inspiron m5030 powering up, black screen. (tried almost everything)
click your left key on your mouse and click restart it should say refresh or restart and re_ program it and system check will pop up then have a system check and it will tell you your problem and how to solve it.
Mar 12, 2013 | Computers & Internet
My computer starts, but empty screen
Sounds like you need to install a display driver.
Mar 08, 2013 | Computers & Internet
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
I have a acer travelmate 5740. When I turn it on the fan whirs for 5 secs then stops. The computer doesn't start and the screen remains black. I've tried holding the power on button for 60 secs as...
hello sir!
it seems that *********** borad or power board isn't working. just take it to some machenic he will repair it in about 20$ or less..
thank you.
Apr 18, 2012 | Acer Computers & Internet
Toshiba tab turns on but Screen stays black what do I do
I would check the ram chips first,, pull them out and reinstall them, most of the time this will work. if not.... try starting the laptop with only one ram chip installed, then try the same thing with the 2nd ram chip install,, test one at a time..
If this dont work it may be a bad GPU connectoin to the mother board,
This can be fixed but in most cases a new mother board is needed.
Jan 11, 2012 | Toshiba Computers & Internet
I formated my PC and I did not have the drivers for its mother board (MS-7525). so I lost the ethernet connection, audio port...etc. I need the drivers for this Mother board
Hello, if you've not already discovered for yourself, the HP website is a superb source of support for your HP product. Start at www.hp.comand have a browse round for support for your device and you'll find loads of downloads there.Regards,nicam49
Jan 10, 2012 | HP Compaq Motherboard
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
My Gateway NV52 will not display anything on the screen. it stays black. The notebook powers up, but nothing is shown on the screen. How can i fix this?
First :
Try connect your laptop to other monitor ( crt or lcd ) if it looks normal on the monitor, it means your LCD laptop is broken.
Somestime often open-closed this LCD Laptop, may broken your Flexy data kabel of your LCD laptop.
Anyway Thx
Jun 23, 2011 | Gateway NV5215u Notebook
Computer is on but blank screen
Check the RAM .
If the problem is same . remove the cmos battery and install again.
Reply me soon.
Hope this help.
Feb 19, 2011 | Intel Motherboard
Foxconn 6627MA-RS2H Motherboard Logo
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
